Page: |
Home > A-Series EFI / Injection > Average opening duration Of MPI injector | |||||||
1346 Posts Member #: 2340 Post Whore Dublin Ireland |
15th Dec, 2009 at 02:15:05pm
Hi folks I am having a bitch of a time problam solving on one of my own MPI's,
Edited by PaulH on 15th Dec, 2009. On 17th Feb, 2009 Rob H said:
15th Dec, 2009 at 02:22:22pm
7mS sounds about right.
15th Dec, 2009 at 02:41:43pm
sorry Paul Like numpty I forgot to say at idel and 2000 rpm On 17th Feb, 2009 Rob H said:
15th Dec, 2009 at 02:47:27pm
It's more dependant on load than speed. As each cylinder needs roughly the same fuel each rev multiplied by the manifold absolute pressure.
520 Posts Member #: 2093 Post Whore Grenoble, France |
29th Mar, 2010 at 04:08:46pm
What's the opening time of std MPI 460cc injectors ? I'm talking about how many ms should I add to the spaying pulse time to get it right at say 14v. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Mar, 2010 at 04:13:49pm
I have my opening time set at 1mSec and it works OK. I'm not sure where the figure came from.
29th Mar, 2010 at 04:23:51pm
Thanks std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Mar, 2010 at 06:07:31pm
Ahh!
On 15th Dec, 2009 Paul S said:
It's more dependant on load than speed. As each cylinder needs roughly the same fuel each rev multiplied by the manifold absolute pressure. So at 2000rpm sucking a good vacuum, it will be similar to idle. On 28th Aug, 2011 Kean said:
30th Mar, 2010 at 10:58:28am
These Delphi injectors are quite fast despite high impedance coil. They exist in many flows from 400cc to about 900. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
30th Mar, 2010 at 11:24:21am
I don't suppose you know anything about the response time of marrelli IWP069 Pico's? i cant seem to find much on it.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
30th Mar, 2010 at 11:25:33am
Turbo Dave reckons the minimum effective opening time is 0.9ms, and I used this figure to model the injector in VEMS with a 0.3ms ramp time and 0.6ms opening time giving the 0.9ms effective opening time. Seems to work well. This is the minimum stable pulse width. Also consider that while the injector is closing, it is still flowing fuel. the ramp time is the time it takes for the injector to start to move its pintle, 0.3ms, then once the pintle is moving the injector starts to flow fuel. it takes 0.6ms to go from full closed to full open. When the injector closes, and for argument sake, it takes 0.6ms to close. the pulse width is the bit inbetween and the software calculates the fuel flow from the data configured as above, subtracting half the sum of the open and close time from the final PW calculation.
Edited by Sprocket on 30th Mar, 2010. On 26th Oct, 2004 TurboDave16v said:
30th Mar, 2010 at 01:35:16pm
It's perfect Sprocket, I'm familiar with the MS way to estimate the opening time.
Page: |
