Page: |
Home > 998cc > 998 with sw5 cam | |||||||
100 Posts Member #: 7614 Advanced Member Malaysia |
1st Dec, 2009 at 01:14:54am
a have a cooper 997cc engine which i want to build with 12g940 head and SW5 cam.
http://www.minimonstermotorsport.blogspot.com/
1st Dec, 2009 at 07:51:30am
Fit a 295 head. A MUCH better bet with that camshaft. On 13th Jul, 2012 Ben H said:
1st Dec, 2009 at 11:13:39am
it already fitted with that 295 head http://www.minimonstermotorsport.blogspot.com/
1st Dec, 2009 at 11:24:38am
Keep it. If you're fitting a SW5 camshaft, this tells me you're after torque. Fitting a 940 head to a small bore engine will remove this mid range and move the power where you don't need it. On 13th Jul, 2012 Ben H said:
1st Dec, 2009 at 11:46:52am
ok.
1st Dec, 2009 at 12:21:56pm
No, the camshaft is most likely slot-drive, and new oil pumps to fit this is easy to get hold of. I take it you are fitting a new pump? On 13th Jul, 2012 Ben H said:
1st Dec, 2009 at 12:28:31pm
yes,it comes as a set.
1st Dec, 2009 at 01:11:14pm
Not if you get a 1.0 oil pump.
2nd Dec, 2009 at 12:16:25am
i might need to check with my customer..
520 Posts Member #: 2093 Post Whore Grenoble, France |
2nd Dec, 2009 at 04:57:39pm
The SW5 fits perfectly a 998 and the slot drive pump. But it has a high lift which means (in theory) you need harder (dual) valve springs. Swiftune sell both springs and pumps, I've got them on my current engine. Not convinced it was worth of money, will go with md265, 295 and std springs next time std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
2nd Dec, 2009 at 05:25:21pm
The SW5 only has about 20 thou more lift than most standard cams so could it really be considered full lift? I will be using single valve springs on my 1098T with an SW5 On 12th Nov, 2009 Paul S said:
Gary's description is best |
388 Posts Member #: 442 Senior Member Manchester |
2nd Dec, 2009 at 07:02:41pm
On 2nd Dec, 2009 GaryOS said:
The SW5 only has about 20 thou more lift than most standard cams so could it really be considered full lift? I will be using single valve springs on my 1098T with an SW5 Same as what im doing but ill be using a 1275 head. |
3rd Dec, 2009 at 12:40:39am
regarding to all,
3rd Dec, 2009 at 10:19:53am
On 3rd Dec, 2009 minimonster said:
also,how if i bored the block? how much need to bore? That kind of depends on what size pistons you use On 12th Nov, 2009 Paul S said:
Page: |
