Home > 998cc > center main strap on a 850cc?
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Would a center main strap on an 850cc motor be necessary, or doable even?
-James
Some would argue that a strap is never necessary. If you are plenning high revs then it's a good idea IMO.
I have no idea about the 850 block but I would assume it is perfectly possible to do something.
miniswordsman
Member #: 6558
I am planning high revs. I don't know that I'll necessarily need high revs, but it's going to be a daily car, and I spend a lot of time on the freeway. I want to be able to go 75mph plus without making my ears bleed though. Do you have one on the 998?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
What final drive will you be running. 75MPH won't require big revs with most standard FDs
On 30th Apr, 2010 Rod S said:
Gary's description is best
miniswordsman
Member #: 6558
I'm not sure, being a daily, I might go with 2.76, or I might keep the 3.44 I have in it now, just in a quaife rather than open diff. I like how peppy the 3.44 is for such a small car. I know I could get a lot more peppy with 3.76 or so, but I don't need that, maybe for my mk1 racer... when I get that built.
GaryOS
Member #: 2810
Dublin, Ireland
Well a 3.44 FD with 165 70/10 tyres gives 4600 rpm which isn't a great amount. I found the 3.44 a little short on motorways though as I like to overtake a fair bit.
I would fit a centre main strap with 6 dash bolts as a matter of course and becasue they are so cheap but I don't know if they are necessary. Hopefully somebody who understands the necessity and function of straps better will help out but I would fit one
Edited by GaryOS on 13th Nov, 2009.
miniswordsman
Member #: 6558
What do you prefer on motorways? As I like to be able to overtake, and with some good sound deadening after the rebuild and a proper dash, even 5500 rpms shouldn't be too unbearable... Besides, I don't terribly mind the a-series scream.
GaryOS
Member #: 2810
Dublin, Ireland
I had a 3.1 with my standard 998 and loved it. It was fine around town too. I have a 2.9 for the turbo motor so we will see how that goes
miniswordsman
Member #: 6558
what speeds were you running with the 3.1?
GaryOS
Member #: 2810
Dublin, Ireland
I didn't have a rev counter but I could happily reach 145km/h on 165 70/10s
I can promise you that a 2.76 on an 850 will not work....
miniswordsman
Member #: 6558
Even if it's turbo'd and built up in the motor? Seems to work on 998's.
