Page: |
Home > A-Series EFI / Injection > Twin Wideband Lamba sensor code for MS | |||||||
Forum Mod 1927 Posts Member #: 1761 Stalker Bristol |
4th Nov, 2009 at 05:40:40pm
I've been in recent talks with Jean Belanger about what would be required to change the MS code to accept the data from two wideband lamba sensors for the sake of 'auto-tuning'.
4th Nov, 2009 at 06:08:12pm
OK,
Edited by Paul S on 4th Nov, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
5th Nov, 2009 at 02:28:18am
I mostly agree with Paul that it would be very difficult to have both fueling and timing controlled in a closed loop and I've already mentioned something along those lines to Carl. However, it might be possible to slightly adjust fueling in dual pulse/table mode but it might require some refinement to take into account the interaction between the 2 cylinders. And it might be possible to do something about timing or fueling in single pulse mode but that would also need some thinking and experimenting.
Edited by jbelanger on 5th Nov, 2009. |
12th Nov, 2009 at 09:22:52pm
Sorry to reply to this so late, completely forgot about the thread!
Edited by Carl S on 12th Nov, 2009. |
12th Nov, 2009 at 10:08:10pm
On 12th Nov, 2009 Carl S said:
Jean, your idea of analysing the wideband data from logs sounds very good indeed, but also sounds like a mammoth task! I think if I was to attempt to try something like that, I would need to meet with either Paul or Rod and discuss it in person, and make notes on it, as I dont think I have enough understanding currently to apply to the data collected by the logs. Agreed that this is a big job. However, it could be done in a stepwise fashion with the most basic model to start with (assuming linear behaviour) and then improve on that as more data comes in to refine the model. Even that way, it's not trivial and would require a significant amount of work to have an initial working version. But if everything is kept as basic as possible with a minimal number of options then it might not be that enormous of a task. In any case, whether through some sort of automated process or by human analysis, I think that it's more likely that offline processing of the datalogs will be more likely to succeed than trying to have some sort of control loop inside the code for the reasons mentioned in the previous posts. Jean |
Page: |
