Page: |
Home > A-Series EFI / Injection > aftermarket ecu for mpi cars? | |||||||
31st Oct, 2009 at 08:14:31pm
Hi, I have just built a fast road engine for my mpi cooper. I will be fitting this to the car when I have some time off in the next few weeks.
1st Nov, 2009 at 10:17:42am
It would be entirely feasible to use the MPi manifold etc with an aftermarket ECU. I'm not sure that it would give you heaps more power, but it would allow you to optimise the fueling and ignition.
Edited by Paul S on 1st Nov, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1st Nov, 2009 at 11:27:34am
As above, but I too am biased.....
1st Nov, 2009 at 12:01:04pm
Good point about the emmissions Rod.
54 Posts Member #: 7429 Advanced Member Leicester |
5th Nov, 2009 at 12:52:01am
Sorry to Hi-jack but something thats been on my mind is the MPI system, i'm planning on building a 1380 turbo engine with cam, head work, T3 etc, would it be worth while (for more power really) to run MPI with the megasquirt management or am i just aswell to keep it carb'd? '89 Austin Metro GTa :) |
5th Nov, 2009 at 07:32:19am
Assuming you mean all the MPI engine parts but swapping the ECU for a Megasquirt, most of the answers are above, the only immediate additional consideration for 1380 and turbo would be injector size. I'm not sure what size the MPI ones are (Paul will answer that I'm sure) but they will be the power limit. And it's not just a case of putting bigger ones in, although possible, as you would start to lose control of idle. So the answer is then staged injectors and that means new or severely modified manifold.
5th Nov, 2009 at 07:58:43am
On 5th Nov, 2009 Gunny said:
Sorry to Hi-jack but something thats been on my mind is the MPI system, i'm planning on building a 1380 turbo engine with cam, head work, T3 etc, would it be worth while (for more power really) to run MPI with the megasquirt management or am i just aswell to keep it carb'd? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
Page: |
