Home > FAQ / Knowledge > Modified exhaust manifolds???
warrior22
Member #: 7274
Southampton
Hi all iam trying to find info and sources for tuning parts and one of the bits i cant find anything on is an exhaust manifold (head to turbo), i have standard one but was looking for an uprated/moded one. any info on where you can get one or even if its worth doing would be grate.
Thanks Danny
MonkeyFish rule
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Nobody makes a T3 manifold other than the standard one. There is the Mirage manifold but that is a compromise in terms of space and it's design looks like it shouldn't flow well. However, Nic's car produced 216hp with it so it can't be that bad!
On 30th Apr, 2010 Rod S said:
Gary's description is best
warrior22
Member #: 7274
Southampton
Oh sounds like iam out of luck with that one, i want to stick with semi standard parts (no wild expermentle re-engineering) so i might just have to clean and polish the one ive got then.
MonkeyFish rule
GaryOS
Member #: 2810
Dublin, Ireland
Yeah, there is no alternative other than making your own if you want a different manifold
warrior22
Member #: 7274
Southampton
Do many people make up there own or is the standard item good for big BHP and boost?
MonkeyFish rule
GaryOS
Member #: 2810
Dublin, Ireland
Not many people make them. Most people use adapters on a standard or mirage manifold to suit whatever turbo they are using. I made mine because I'm using an oddball turbo
Benross will port your manifold. So will turbo phil.
Both members on here.
doesnt mat (miniwilliams) run the std manifold and push 300+
yes.
The only down side to the standard manifold is the need to fit the bulkhead box.
and i would say that there are more things to worry about than the "apparent" restriction of flow in the mirage manifolds *wink*
They have the advantage of fitting more suitable turbos (although the metty turbo one can be modded) and no bulkhead box as paul said.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
After seeing Iains performance at MITP, you can't fault the Mirage style manifold.
