Home > 998cc > How bigs to big?
blake12345
Member #: 3103
I have a 1098cc thats been bored 80thou. Is this to big to turbo or supercharge? Also what kind of compression would i be aiming for?
Thanks Blake
Not too big at all. Depending on use and poer wanted, somewhere between 8.5 and 9:1 is what I'd aim for.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I'm turboing a +0.060" 1098. 24.5cc chambers, 7cc dished hypatecs and a CR of 9.2:1 iirc
On 30th Apr, 2010 Rod S said:
Gary's description is best
blake12345
Member #: 3103
Thanks, its being used for everyday use but a majority of my driving is on back roads doing 50 odd mphs 90% of the time. I wasnt looking for huge power but i like the idea of having abit of power on tap if i needed it.
I was only looking at running about 6psi. Would it be worth doing it with only 6psi?
Thanks Blake
GaryOS
Member #: 2810
Dublin, Ireland
Definately! Take a look at Wil's "How To Turbo A Mini In 20 Hours". I think that runs at 6psi on a 998 and its a TM legend
blake12345
Member #: 3103
Yeh ive had a look at that quite a few times now. The main thing was, i was concerned about the cylinder walls being to thin.
Blake
GaryOS
Member #: 2810
Dublin, Ireland
No need to worry. There are up to +0.120" 998 pistons available and being used on twin cam builds. 998 blocks are the same as 1098s. If there are reliable 1380 turbos then I wouldn't worry about wall thickness on a small bore
blake12345
Member #: 3103
Well now i know that i better start sourcing some parts.
I have a TD04-09 in the garage, will this be to big for what im looking at?
GaryOS
Member #: 2810
Dublin, Ireland
TD04 is used for the higher power Saabs over the GT1752 so it's probably way too big. What are the trim and A/R figures? Have you got a compressor map for it?
blake12345
Member #: 3103
Yeh this one is off a Mitsubishi Delica. I dont have any info. other than that for it as i picked it up from a mates wreckers for nothing. It hasnt got any play and seems to be in really good condition so i thought id take it.
BUt if its to big i might try and swap it for a smaller turbo then. The T02 is what i should be looking for isnt it?
Thanks Blake
