Home > 998cc > valves for 12g295 head
DVSMNI
Member #: 3668
NEW ZEALAND - moving to Australia
hey people just wanted to no what valves people are using if they are using a 12g295 head on there 998 turbo, simple reason is im on a budget and i wana see wat i can get for money and wat people have had that work, i been told i could use 1275 standard valves but not to sure or sodium fill but they are an arm an a leg to buy. any thoughts on wat ur using would be great cheers.:)
1966 MK1 1034CC TURBO MINI
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I have 33mm single collet minispares 1275 inlets and I think they are 26.4 mm triple collet minispares exhausts
On 30th Apr, 2010 Rod S said:
Gary's description is best
No sodium filled valves required.
Just use good quality valves and guides and have the exhaust guides relieved to reduce the chance of binding.
DVSMNI
Member #: 3668
ok so if i use some good quality 1275 valves that will be ok, can u teflon coat valves they do it alot over here for the pistons in mini 7 race cars ? is it worth it if u can ?
Never heard of that.
Not had a problem using standard valves, so it would maybe be overkill.
if you want some valves give me a pm i have many standard ones
DVSMNI
Member #: 3668
benross only problem is im in new zealand haha so im not sure sending them all the way out is gna be cheap, if worse comes to worse ill send u a pm if we cnt sus somin out here, they guy whos building my engine builds mini racing engines hes sum wat of a guru haha, cheers for ya help guys.
1275 valves are a bodge. Stey clear.
Minispares sell some very nice 31mm inlets and 26.5mm exhaust valves. Failing this, you could call Paul Ivey, he's got some 32mm/27mm rimflo valves which are cheap and very good.
The service is fantastic also.
Andrew 998 mini
Member #: 5639
Weert Holland
Hi I would like to join in here i have decided to just bolt my 12g295 head on for now ( sorry ben but you will be asked to do you magic in the future for me), how ever i would like to fit new valevs and guides for peace of mind and just genraly tidy the head up be for i use it.
I have just taken the valves out an they mesure
Intake (MOWOG AEA 400) 31.7 mm
exhaust (unknown?? eny ideas?) 25.1
Sorry Chaps I have made a classic mistake *surprised*:$ and muddled the numbers *surprised* I have now re mesurd them hope these mesurments are mor like what suld be in the 12g295 Head.
I would like to get new valves / guides / springs etc Who can recomend wat to get I see alot of stainless mentiond and bronze guides.
Thanks
Edited by Andrew 998 mini on 11th Jan, 2010.
Cheers, Andrew
Little car Little power........... For now That is!!!!!
1983 mini down paid, must collect soon and get welding!
Advantage
Member #: 1450
Near Paris - France
You probably don't have those valves on a 12G295 ...
Rusty by nature
Andrew 998 mini
Member #: 5639
Weert Holland
Aha, Oke, where do i mesure the valves?
perhaps time for a digital vernier caliper or how ever you call it
Cheers, Andrew
The best standard size valves for the 12G295 are these:
[url]http://www.minispares.com/Product.aspx?ty=pb&pid=33367&title=VALVE EXHAUST 1.040[/url]
[url]http://www.minispares.com/Product.aspx?ty=pb&pid=33657&title=VALVE INLET 30.93mm SHORT...[/url]
But it sounds like you may have a modified head with those sizes you have measured.
EDIT: Links wont work for some reason.
Loook for C-AEG587 & C-AEG588
Edited by Paul S on 11th Jan, 2010.
Advantage
Member #: 1450
Near Paris - France
Vegad recommended I use these :
http://www.minispares.com/Product.aspx?ty=...on%20LEADFREE...
as exhausts (or maybe I misread what he was writing
Rusty by nature
I have previously done that, but that was mostly because the 26.5mm exh was too small. If a 26.5mm valve seat will clean up the old one, I'd use that.
Advantage
Member #: 1450
Near Paris - France
What ?
I was about to follow that advice like the tables of the law !
Vegard how can I trust you now ???
And also it was very good sense ...
Rusty by nature
Advantage
Member #: 1450
Near Paris - France
Does that mean your seat had sunk so you used a bigger valve to do away with a new seat ?
I thougt a bigger exhasut valve was wortwhile on turbo application because inlet being now boosted, the new bottle neck is now the exhaust.
But all in all it is not worthwhile, is it ?
Rusty by nature
Yes, the seat was so worn, so instead of fitting a new valve seat, i fitted a bigger valve..
