Page: |
Home > How To > SPi / MPi Tank Plumbing / Wiring | |||||||
22nd Nov, 2004 at 12:01:19am
Below is a pic of an MPi tank. As i understand, the SPi are exactly the same...
Edited by AlexB on 28th Apr, 2008. On 17th Nov, 2014 Tom Fenton said:
Site Admin 6277 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
28th Apr, 2008 at 02:17:54pm
Bumping, as I had to edit this to fix the pic - I needed it! |
2500 Posts Member #: 648 Post Whore Northern Ireland (ex AUS) |
6th Apr, 2009 at 03:09:01pm
I hope you don't mind me asking in a how to section but do people use two spade connectors to plug into the pump or do they source a plug from somewhere? :) On 7th Nov, 2008 Nic said:
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
15th Apr, 2009 at 06:46:42pm
a matching connector can be found in many cars, most use it at the screen washer pump |
6274 Posts Member #: 509 Post Whore Isle of Man |
15th Apr, 2009 at 08:09:42pm
nfauto, or vehicalwiringproducts will prob be your best bet "Turbo's make torque, and torque makes fun"
15th Apr, 2009 at 08:14:05pm
Or you can use two standard 6mm female shrouded spades as I did on mine. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
15th Apr, 2009 at 08:19:06pm
Thanks guys, I have been held back with things so I haven't thought any more about this. I have insulated spades on at the moment, does anyone know the current draw by the pump? On 7th Nov, 2008 Nic said:
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
15th Apr, 2009 at 11:15:05pm
Just thought Id add this as a guide, might be of use tho someone.
297 Posts Member #: 2276 Senior Member sheffield / derby |
30th Jul, 2009 at 03:04:28pm
hi
59 Posts Member #: 5708 Advanced Member Galway, Ireland |
1st Aug, 2009 at 12:35:51pm
does anyone have a diagram to wire up to ignition thanks |
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
1st Aug, 2009 at 06:25:49pm
shane in that diagram relay No1 is not needed. if you put the fuzed 12v feed straight into pin 30 on relay No2 it would function the exact same :) turbo 16v k-series 11.9@118.9 :)
4th Aug, 2009 at 10:52:51pm
I know if it is used just for the pump it only requires one relay, but was using the n/o and n/c contacts for other things.
384 Posts Member #: 4215 Senior Member |
16th Jan, 2010 at 01:37:42am
quick question, what does the relay do? and do i need it? as i have just wired mine up, without any relay? also do i need that oil pressure switch wired in?
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
16th Jan, 2010 at 08:59:16am
The relay means that you can supply the pump with a good power source (e.g. direct from the battery), but have it switched on/off by the ignition or oil preasure switch etc. Running it direct from the fusebox/loom etc you run the risk of over loading the circuit, blowing fuses, melting wires etc etc On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
16th Jan, 2010 at 04:30:19pm
oh ok mate... i ran my wire from the ignition, with an inline fuse..so i think it should be ok...
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
16th Jan, 2010 at 05:17:54pm
The point of using the oil pressure is so that if you have an accident, the likelihood is that the engine will stop and hence the oil pressure will drop and the fuel pump will stop. This can be done in other ways, drive it of an ecu like the megasquirt, this stops the pump if the engine stops or possibly run it through an inertia switch. Or do all three. http://www.twin-turbo.co.uk
17th Jan, 2010 at 02:35:46pm
thanks for the insight mate...
Page: |
