Page: |
Home > Show Us Yours! > 16v Project Progress - Now Back in Business | |||||||
4304 Posts Member #: 1321 Post Whore Wiltshire |
9th Jul, 2009 at 11:21:29pm
well, having decided my car is far too heavy it has come apart again for a serious diet.
Edited by minimole23 on 11th Aug, 2021. On 7th Oct, 2010 5haneJ said:
1252 Posts Member #: 1656 Post Whore stoke-on-trent |
9th Jul, 2009 at 11:56:48pm
why use the tree when you had the tractor?? On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
1745 Posts Member #: 375 Post Whore Leicestershire |
10th Jul, 2009 at 12:00:05am
Thats some good wait saving! And the turbo will definately make it more fun
10th Jul, 2009 at 12:05:45am
We used the tractor to load it onto the trailer because it was at a farm. then took it home and had everything I needed off it, it never left the trailer before getting weighed in i'm afraid, it was only here for one day. On 7th Oct, 2010 5haneJ said:
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
10th Jul, 2009 at 09:07:24am
How much weight did you get out of the door?? Will your windows still work or is the mechanism too heavy? On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
Forum Mod 5933 Posts Member #: 784 9 times Avon Park Class C winner Milton Keynes |
10th Jul, 2009 at 11:11:06am
Pic 3. Hard grinding disks and aluminium dont mix. The alu clogs up the disk then expands with heat, then explodes!
I seriously doubt it! |
10th Jul, 2009 at 12:22:04pm
I'm keeping the winder mechanisms, they weigh 1.5 kg though I have cut about 250g out of each one. It would be nice weight to loose but I want it to be enjoyable to drive and not boil. plus it will look smart some carbon doorcards i'm going to make. overall I should think only about 1kg will come out of each door.
69 Posts Member #: 1670 Advanced Member |
10th Jul, 2009 at 01:56:54pm
Wouldn't Electric Windows be lighter ?? |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
10th Jul, 2009 at 06:34:23pm
Yes. Electric windows are way lighter than the standard mechanisms. |
10th Jul, 2009 at 07:03:29pm
what would be a good donar vehicle for mechanisms On 7th Oct, 2010 5haneJ said:
11th Jul, 2009 at 12:04:39am
On 10th Jul, 2009 minimole23 said:
what would be a good donar vehicle for mechanisms Electric ones?? A conversion kit is probably the easiest. |
13th Jul, 2009 at 08:32:29am
Try Wood and Picket for the ellectric window kit On 11th Feb, 2015 robert said:
27th Jul, 2009 at 01:52:39pm
Well, After much notching, trial fitting, swearing, then re-notching I have a fair bit more rollcage in now. I will offset this added weight with a fibreglass roof and rear beam when I have the money.
1733 Posts Member #: 1910 Post Whore Wilts |
27th Jul, 2009 at 04:02:37pm
Looks great matey!
the pissed up clown stood back up, did a twirl and left bollock naked, |
27th Jul, 2009 at 05:43:25pm
Cage is looking good, just need some gussets! Isambard Kingdom Brunel said:
27th Jul, 2009 at 06:02:23pm
I got confused and thougt the cage was in the metty, same coulour see... lol On 28th Aug, 2011 Kean said:
5329 Posts Member #: 140 Proven 200+bhp & Avon Park 05,06,07 Class D 3rd place |
27th Jul, 2009 at 06:05:25pm
looks good what you have done, i love the engine crane Best 1/4 mile 13.2 seconds @116 mph
17th Jan, 2010 at 09:43:00pm
I have decided to sort a number of things with the car that have needed doing for ages.
17th Jan, 2010 at 09:53:19pm
Top work going on here buddy!
17th Jan, 2010 at 10:16:00pm
On 17th Jan, 2010 minimole23 said:
I only need to make some gussets to tie the screen pillars to the rollcage then thats totally done. Do you want to borrow my hole punch & flaring tool? On 17th Jan, 2010 minimole23 said:
I broke the hole saw earler attempting to cut through the bulkhead so need to get a new drill bit for it. Strangely I wrecked a couple of hole saws this morning trying to drill my bulkhead for the internal gear linkage. Edited by Rob H on 17th Jan, 2010. Isambard Kingdom Brunel said:
8th Aug, 2010 at 09:31:02pm
Its been rather a long time since I updated, as I've not had much worth updating to be honest.
67 Posts Member #: 8744 Advanced Member |
10th Aug, 2010 at 07:30:21am
Where did you get that cage from mate? |
1849 Posts Member #: 672 The oversills police Oslo, Norway |
10th Aug, 2010 at 08:01:39am
On 8th Aug, 2010 minimole23 said:
The inner mount for the radius arm looks scary!? Edited by miniminor63 on 10th Aug, 2010. |
10th Aug, 2010 at 08:31:24am
How come? its the same mount as a coupe of others on this site have used. Is that it looks like it needs a bit more of a gusset higher up where the radius arm clamps up?
10th Aug, 2010 at 08:40:24am
On 10th Aug, 2010 turbomikee said:
Where did you get that cage from mate? Its a safety devices bolt in cage which I welded in with a few extra bars 2 years after fitting it. On 7th Oct, 2010 5haneJ said:
Page: |
