Page: |
Home > Rod trials and testing > AFR Sample Chambers - Take 2 - R | |||||||
26th Jun, 2009 at 05:00:48pm
(retrieved, I lost the file last night while editing it in Word......)
Edited by Rod S on 27th Jun, 2009. Schrödinger's cat - so which one am I ??? |
27th Jun, 2009 at 06:21:50pm
So I've welded most of it up....
27th Jun, 2009 at 06:27:53pm
Looking good. No possibility with reverse flow up the sample pipe with that setup.
27th Jun, 2009 at 06:38:41pm
On 27th Jun, 2009 Paul S said:
You're happy that you will be able to fit it with the engine in the car? No..... I said in an earlier post, but I think it got lost while I was editing it.... No. it will go in assembled on the engine - flip front will allow me to do so. I think it could be modified slightly to allow fitting in the car though. My main criteria was to have the LSUs easily removable (in the car) for FAC. Schrödinger's cat - so which one am I ??? |
28th Jun, 2009 at 07:24:56am
No possibility with reverse flow up the sample pipe with that setup. It only occured to me last night after I'd shut the PC down...... It wasn't a deliberate attempt to "improve" on your design, it was pretty much dictated by the use of the Metro old fashioned T3 setup, ie, having to go in below the cast iron elbow. BUT - I've now realised that because of that constraint, I unwittingly designed it so it will also work with the standard turbo SU setup.... Maybe someone might want to copy it and see just how far out the AFRs go (between inner and outer cylinders) with an SU under boost. Schrödinger's cat - so which one am I ??? |
Page: |
