Home > 998cc > just searched about for a supercharger 998 build and mine needs help
blister
Member #: 2590
Croydon
i just bought a m45 supercharger thats done very low miles from ebay i am after putting it on my 998 i know i need a belt tensioner and i am going to be getting this from vmax
i was just wondering do i need to mod my pulley that the supercharger belt goes to? also i am going to use a decompression plate what cc do i need its a standard 998 and will be using standard pulley size and no skimming has been done to standard head
998cc city E stage one fitted at the moment and what sorted of extra power will i get from it with the charger oh and its going to be suck through
If you're going to be building this engine, you should really know the answers to these questions. Unless you understand, you will go the same way as many others who have tried to build similar engines, i.e. up in smoke.
When I built my first turbo motor, I decided a target bhp that I wanted, then worked out what I needed to achieve this. Not just bolt stuff on and hope for the best.
Based on what questions you have asked so far, I think it may be sensible to buy a kit for your first install.
Agree with Wil, plus the standard head is crap, if you're looking for any kind of decent power get a 295 on there.
The M45 is a bit too big for a 998, so your first problem will be to get a special pulley designed and made so that you can get the speed down to something suitable.
Then you will get too much heat as the blower is operating inefficiently. Then you'll have head gasket problems. Then you'll get burnt pistons because of detonation. Then you'll wish you never started.
Please excuse my Monday morning negativity.
Andy500
Member #: 2443
Cheshire
Wish someone had told me that a couple of years ago...............oh well we live and learn!
Have you been charging a 998 too Andy?
Andy500
Member #: 2443
Cheshire
Sorry, no mines a 1293, but the problems with the M45, boost pressure and corresponding charge temps have all reared their heads on mine. Wish i had gone the turbo route in all honesty.
