Page: |
Home > A-Series EFI / Injection > Manifold Designs | |||||||
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
10th Jun, 2009 at 11:05:52pm
Hello folks, i've been following Paul and Rod with their testing in to the 5 port A series injection, which has made me start thinking of alternative solutions in terms of manifold designs.
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
10th Jun, 2009 at 11:44:17pm
if you could get baffles in to the head all the way down to the valve, then in theory you will have a 7 port head, and injection is easy. Although the port size will be quite small. On 15th May, 2009 TurboDave said:
10th Jun, 2009 at 11:45:55pm
On 10th Jun, 2009 Jimster said:
if you could get baffles in to the head all the way down to the valve, then in theory you will have a 7 port head, and injection is easy. Although the port size will be quite small. Yeah it would be the baffle extending past the external port face to within the head, with the baffles slotting in to the head so to speak. |
11th Jun, 2009 at 12:13:20am
if you could get baffles in to the head all the way down to the valve, then in theory you will have a 7 port head, and injection is easy. Although the port size will be quite small. Yeah it would be the baffle extending past the external port face to within the head, with the baffles slotting in to the head so to speak. remember discussin a head on here that i thought was made this way, but aparently itwas a 7 port casting as seen it at a show, the inlets were as square and large as they could be (but still quite small) with a devider down the middle. turbo 16v k-series 11.9@118.9 :)
11th Jun, 2009 at 12:41:24am
11th Jun, 2009 at 12:44:49am
The port separator has been done but it was at the expense of a significant loss in flow due to the resulting small ports (even extended to the maximum the head will take).
11th Jun, 2009 at 01:10:07am
Hi Jean, thanks for your input. With regards to the second idea, I do mean using 4 injectors instead of 2, on both designs, so I would have thought the load would not be as taxing on the injectors in this scenario? As apposed to having 2 very large injectors, which as you say would have great difficulty giving smooth idle.
Edited by Carl S on 11th Jun, 2009. |
11th Jun, 2009 at 01:28:29am
The 4 injectors will not be able to use more than the 15-20% duty cycle I quoted. Think about it: each injector can only inject when the intake valve is open for one cylinder. That's about 25% of the cycle and you have to remove some portion due to overlap and other factors. Even if you say that the factors which led Paul to assume a 15-20% duty cycle are limitations due to using only 2 injectors, it's still only a quarter of the cycle that can be used.
11th Jun, 2009 at 08:04:08am
The making a 7 port out of a 5 port idea has been done many times before. i believe that the manx 7 port head was just this.
http://www.twin-turbo.co.uk
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
11th Jun, 2009 at 08:46:30am
I think that we already have a solution to fuel inject a turbocharged 1275 to 200+hp and hope to prove that by Christmas.
11th Jun, 2009 at 11:21:47am
Maybe then the first idea could work well for small bore applications?
11th Jun, 2009 at 11:32:50am
Developing an understanding of the siamese code and working setups is challenging and is not for the faint hearted.
3594 Posts Member #: 655 Post Whore Northern Ireland |
11th Jun, 2009 at 12:53:54pm
With divided ports....how does the port area actually compare to the area that the intake valve allows to pass ?
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
11th Jun, 2009 at 01:36:24pm
My thoughts, pretty much as above...
11th Jun, 2009 at 03:53:19pm
If a standardized setup is developed then tuning the injection timing would only have to be done once and could be re-used from then on. So the tuning for a new installation would only consist in tuning the mixture and ignition timing as for any injection setup. Of course that assumes the setup is really standard and that the injectors are large enough that there is some margin in the injection window for the inevitable differences in VE and air/fuel speed.
11th Jun, 2009 at 04:03:38pm
I'd imagine injection timing would change depending on airflow, and more important...cam timing.
11th Jun, 2009 at 04:08:37pm
On 11th Jun, 2009 stevieturbo said:
I'd imagine injection timing would change depending on airflow, and more important...cam timing. Different cams will open/close at different times, and hence require different setups. True, but most cams are at maximum lift at the same point 105-110 degrees, so if we develop a solution aimed at getting the fuel in close to and either side of that point, then the cam timing will not be such an issue. I've found that injector spray nozzle type is a greater factor, particularly at idle. We just need to nail the effect of a cone spray against a pencil stream. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Jun, 2009 at 06:19:22pm
On 11th Jun, 2009 jbelanger said:
I'm biased on this but it seems to me that planning development with a known compromised setup is kind of pointless when there is an alternative right now. Of course more work needs to be done to really understand all the dynamic aspects but the potential is there and will only improve as more people get involved. Jean Surely making software that ovecomes the inadequacies of the inlet system already is a compromise! I don't mean that in a bad way, just I have spent my life making badly designed hardware work by writing tones of code. As for the sealing issue, I don't think that a perfect seal will be necessary. Port robbing will not happen through small gaps. Again I am biased because I only do small bore and I have given this a lot of thought already. http://www.twin-turbo.co.uk
11th Jun, 2009 at 08:00:01pm
Of course, no matter what you do, working with a 5-port head will be a compromise.
12th Jun, 2009 at 02:27:14pm
Jean, I noticed you mentioned earlier about only around 20% of the time being available to inject a perticular cylinder with fuel at any one time, with the 20% roughly representing how much of 720 cycle the inlet valve is spent open. With a pencil stream type injector, are you not able to pre-prime each valve port with fuel before the valve opens, increasing the percentage of the cycle available? This is of course still assuming you can 'aim' the injectors at their retrospective ports inside the head. |
12th Jun, 2009 at 02:50:46pm
Most of the fuel injected when the intake valve is close on the outer cylinders will be going to the inner cylinders but the opposite is not true. Due to the turbulence, any fuel that is in the air in the port will be ingested by the cylinder once the intake valve opens. And that will favor the inner cylinder 3:1 due to cylinder timing.
12th Jun, 2009 at 02:59:04pm
OK, that makes sense. Thanks for taking the time to explain.
Page: |
