| Home > 998cc > Crankshaft | |||||||
238 Posts Member #: 1649 Senior Member West Sussex - dreaming of forced induction! |
29th May, 2009 at 08:07:41am
Hi Guys,
29th May, 2009 at 08:58:20am
i think the only debateable thing is blading as it removes the counterweight, as far as the rest of is concerned it can only help, but to be only, as the 998s a tough little cookie already, i was just going to get mine hardened and balanced. "Turbo's make torque, and torque makes fun"
29th May, 2009 at 09:10:44am
MED will be one of the cheapest for crank work, Fastcarl on here might be able to beat them though
I seriously doubt it! |
29th May, 2009 at 09:17:29am
So, x-drill, lighten, wedging and tuftriding then |
29th May, 2009 at 10:33:47am
What is considered revving the nuts off?
29th May, 2009 at 11:43:21am
When you say grind what do you mean?? I want it to survive to beyond 8K in short bursts, was thinking if it was lightened it would pick up that little bit quicker??? |
29th May, 2009 at 12:20:23pm
I just meant grind the journals before hardening them.
29th May, 2009 at 01:02:37pm
Oh I see LOL
29th May, 2009 at 01:22:05pm
I always get confused trying to calculate psi on an SC engine. However, running an M45 at 15000 rpm will pump enough air for over 200bhp at 8k on a 998; which is maybe a little optermistic. This would also be at 30 odd psi, which is way beyond the capabilities of the M45.
29th May, 2009 at 01:31:56pm
See, thats why I like this forum!!!
29th May, 2009 at 01:51:32pm
You'll be running about 60% efficient maybe a little better lower in the rev range, so the bigger the better.
29th May, 2009 at 01:56:51pm
With all Carl's TI butt plug work he probly likes it closer to 12" but he is a bit special On 17th Feb, 2009 Rob H said:
29th May, 2009 at 01:59:50pm
11 posts before it went 'of topic'. That's pretty poor.
29th May, 2009 at 02:58:36pm
OK, will see what size I can fit in there then, I thought 10" square was being generous, I wouldnt be able to walk properly for weeks after that girth LMAO
