Page: |
Home > Help Needed / General Tech Chat > good brakes to fit under mk1 wheels . | |||||||
![]() 6748 Posts Member #: 828 Post Whore uranus |
28th May, 2009 at 08:17:44am
bit of a dillema ,
28th May, 2009 at 10:54:54am
I have the standard 7.5" cooper S brakes and I slip a set of 10x3.5" wheels on for MOT purposes and they fit on mine. OK it must be pretty snug under there but it still clears nicely. On 7th Nov, 2008 Nic said:
28th May, 2009 at 11:25:52am
Keith Timpson had the eary cooper set up on his van a few years back. I can't recall how good they were though. one benefit is that they don't seem to affect the track width as much as the S set up If I recall right so no need for arches |
28th May, 2009 at 11:57:34am
7" Cooper discs are not very good, but you don't have to adjust all the time. That's teh only upside.
28th May, 2009 at 12:59:59pm
i've got 7.5 S discs and 4.5 reverse rims and no arch's, never had a problem with the mot |
28th May, 2009 at 03:10:44pm
cool thanks all ,sounds like i need to do another check on the 7.5 front , are all 3.5 steel wheels the same ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th May, 2009 at 03:39:04pm
I have S diska and std steels on mine, no fitting issues at all.
I seriously doubt it! |
28th May, 2009 at 03:47:41pm
On 28th May, 2009 robert said:
cool thanks all ,sounds like i need to do another check on the 7.5 front , are all 3.5 steel wheels the same ? not all 3.5 steel wheels are the same, S wheels have round holes between the stud flange thingy and the rim where standard wheels have slots, dimensions would be the same though. 4.5 S wheels had 1" more inset and 4.5 reverse rims have 1" more offset |
28th May, 2009 at 06:49:40pm
paul ,what i did ,was get a s hub and disk and caliper wack it all together on the bench ,and then try to put a wheel on it ,but maybe i got it all a bit different to how it sits on the car ..
28th May, 2009 at 09:24:42pm
i had 8.4 dics turned down to 7.5 and the 4 pot caliper moved in a bit, i could fit loads of 10" wheels but not the steels |
28th May, 2009 at 10:37:43pm
Robert, I knew with your track record the S setup would be too "off the self" for you! let use know how you get on. On 7th Nov, 2008 Nic said:
28th May, 2009 at 10:55:45pm
i had a bit of an experiment today with a fiesta caliper ,and a modern 8.4 hub and flange ,,and it looksl ike with about 3mm spacing , ican get it all to miss ,time will tell. I have F-Brakes on my car and the std steel wheels wont fit because the internal lip on the steel wheel catches the caliper. Like you say spacing the wheel out might work. BTW they have been excellent brakes I run std premium pads, dot 5.1 and they worked great at castle coombe last year at the miniworld track day. even on the last lap I gave them some stick and they stopped great. I run a supercharger and I don't care the TB is on the wrong side.
![]() 274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
28th May, 2009 at 11:17:03pm
7.5 inch Cooper S brakes should fit MK1 wheels. Though if you have the early and dangerous spot welded (pre 1961) wheels, you may have a problem other than fitment.
Edited by Lance Link on 28th May, 2009. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
29th May, 2009 at 07:28:09am
i think Robert will try something a little different, def dont use 7" cooper discs as the crap and twin leading shoe is better, if you go 7.5" S discs then get the minispares carbon metalic pads, they are amazing, easily worth the money, good bite, light peddal and dont fade (and no i dont work for minispares!) |
29th May, 2009 at 07:49:31am
I would't use Carbon Metallic pads on a road car. Albeit being good, they make a SHITLOAD of dust..
29th May, 2009 at 08:22:22am
will be doing some machining today ill let you all know how i get on ,thanks for all the comments . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th May, 2009 at 06:37:15pm
thats better ...
Edited by robert on 29th May, 2009. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th May, 2009 at 06:45:43pm
On 29th May, 2009 robert said:
oops Is this a comment about how well the machining went! lol Edited by matty on 29th May, 2009. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th May, 2009 at 06:53:26pm
nice,
29th May, 2009 at 06:54:18pm
2.6mm joe. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th May, 2009 at 09:03:18pm
That video is rather hypnotic Isambard Kingdom Brunel said:
29th May, 2009 at 11:30:36pm
and the trademark thumbs up!
Page: |
