Page: |
Home > A-Series EFI / Injection > Stand off Injection | |||||||
1346 Posts Member #: 2340 Post Whore Dublin Ireland |
22nd May, 2009 at 10:54:12pm
Ok I am thinking of running Injection on my Daily Hack mini I am sick of Carbs and there in tune ability.
Edited by PaulH on 22nd May, 2009. On 17th Feb, 2009 Rob H said:
3588 Posts Member #: 655 Post Whore Northern Ireland |
23rd May, 2009 at 01:13:13pm
Would such a system still suffer from the problems of port injection ? 9.85 @ 145mph
559 Posts Member #: 2775 Post Whore Aberdeen |
23rd May, 2009 at 01:17:22pm
Is it not just effectivly a single point injection. Would there be any advantage doing this way over controling a single point injector setup? |
23rd May, 2009 at 05:17:08pm
Well It would be simlar to the Single point but there will be one per port.
23rd May, 2009 at 05:30:51pm
I'm not familiar with "stand off" injection but I assume from your sketch, the injector is a long way away from the valves (even before the throttle plate in the sketch).
23rd May, 2009 at 05:44:46pm
I think by stand off, he means running an injector at a distance, as opposed to pointing at the valve. 9.85 @ 145mph
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
23rd May, 2009 at 05:48:48pm
http://www.youtube.com/watch?v=AKyP19ky_W0&feature=related basically as per the diagram :) Edited by evolotion on 23rd May, 2009. turbo 16v k-series 11.9@118.9 :)
23rd May, 2009 at 05:57:19pm
I had a feeling it might be like the video from the description and sketch....
23rd May, 2009 at 06:12:52pm
I don't know about stand off, but I would not hesitate to recommend a couple of Jenvey or bike TBs with the latest MS2/extra code that I'm using.
23rd May, 2009 at 06:28:53pm
Sorry I thought you meant one single TB with 1 injector replacing a single carb. Are there any bike TB's that lend themselves to mounting car injectors? |
23rd May, 2009 at 06:59:04pm
I would tend to agree with Rod on this.
23rd May, 2009 at 07:24:30pm
Well I would have no worries about the safety of this on a road car since at no point will you ever have a totally closed throttle butterfly,
23rd May, 2009 at 10:36:22pm
There would only be a safety risk if the fuel was being sprayed with no enclosure...
11046 Posts Member #: 965 Post Whore Preston On The Brook |
24th May, 2009 at 06:34:30pm
You can pick up a standard factory fit SPi manifold on fleabay for around £20.
Page: |
