Home > A-Series EFI / Injection > Anyone running closed loop/adaptive with Emerald
Andy500
Member #: 2443
Cheshire
Im toying with the idea of letting my supercharged mpi run in adaptive mode on the M3DK ECU. Ive done a search on here and found jimsters post which has been pretty usefull.
Is anbody else running theres in adaptive and is it worth it? It needs to go back to Emerald in a couple of months anyway once i have the charge cooler fitted and have slowed the blower down (if i still need to)
What should i input my target AFR as?
is it worth having a go or should i leave it to Dave to sort out and should i ask him to set up the adaptive function?
I used closed loop before, but now my whole map is adaptive, it works very very well. I'll share my settings with you if you like Andy. What wide band are you using? as I found my aem gauge didn't quite output the 5v it should
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Adaptive is best used for fine tuning...
Get the car mapped then allow the ECU to fine tunr the last tiny bit.
Remember your only considering the fueling and thats not where you want ot be focusing your efforts.
Alex
AlexF
Andy500
Member #: 2443
Cheshire
Thanks Jimster, Im running an LC-1. Dave has mapped the car which now runs pretty well but i thought the adaptive may well be worth a shot.
I tried it a couple of nights ago and it was crap mid range when you put a bit of throttle back on but i dont think its set up right yet.
