| Home > 998cc > My 998 | |||||||
![]() 67 Posts Member #: 5547 Advanced Member Ayrshire, Scotland |
14th Mar, 2009 at 11:17:31pm
Olla alll
14th Mar, 2009 at 11:20:41pm
Also, Denis (evolution) said you also need to think about the distributor , you can run one, but most convert to megajolt and EDIS for ignition.
Could i just run a leccy ignition? whats the diffrences of the above? never heard of them in my nelly puff |
14th Mar, 2009 at 11:47:55pm
Cam:
14th Mar, 2009 at 11:56:27pm
HA cheers fella, i was reading other threads there, (doing the same as what u've done but i havn't posted anything)
15th Mar, 2009 at 09:25:42am
There's a good thread on megajolt. basically you get full control of when you get your spark, controlled by a brain.
Edited by apbellamy on 15th Mar, 2009. On 11th Feb, 2015 robert said:
319 Posts Member #: 1742 Senior Member essex |
25th Mar, 2009 at 06:08:34pm
dont go and blow a load of money on high lift rockers. They are not ideal on a 998 especially if you are going for a 1275 head just select a good cam. others may say different My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
25th Mar, 2009 at 07:27:50pm
i've heard that since writing this.
3rd Apr, 2009 at 04:11:57pm
I've been offered a t2 turbo off a feista turbo, the guy says
as far as I can tell if anything it might just need new oil seals, but as I say I dont know, theres minimal play so you'd imagine its fine.
is this worth buying and would it be usable on the engine??? |
3rd Apr, 2009 at 07:38:44pm
no, "nmay need new oil seals" is a polite way of saying its fucked. buy somthing else. turbo 16v k-series 11.9@118.9 :)
