| Home > Help Needed / General Tech Chat > Making a carb boost sensitive..Turbodave? | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
15th Oct, 2004 at 04:01:04pm
Even though I am still taking my engine to bits/cleaning up, etc. I have decided that my M45 blower is going to be where the alternator goes, through a Vauxhall intercooler which is pretty much spot on and then into a blow through HIF 44. Bugger off, I'm getting there. |
16th Oct, 2004 at 04:47:41pm
I have a picture at work that explains it all. I'll upload it monday. As you suspect, a nat-asp is easilly modified into blowthru spec... On 17th Nov, 2014 Tom Fenton said:
20th Oct, 2004 at 01:32:36pm
I bumped into the "Fabricating your own plenum" thread and couldn't decide if keeping the restrictor ring was 100% necessary. Vizard seems to show a ring inside the carb, I suppose that making the "hole" in your plenum a bit undersize would have the same effect.
20th Oct, 2004 at 02:08:24pm
I think it is the length of the ring that is quite important rather than the size (diameter) of it. I think this is because the length means that no air flow can be 'sucked' round the corner (for want of a better explanation?) for instance like you get with a radiused ram pipe.
20th Oct, 2004 at 07:48:16pm
i thought the diameter was the most important as it creates a pressure drop across the carb mouth. |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
27th Oct, 2004 at 01:49:19pm
did you ever find the pic dave? would be very interested......
And on the 7th day........... God created turbochargers! |
27th Oct, 2004 at 02:35:03pm
I will see if I can drag anything off the sphincternet. Bugger off, I'm getting there. |
27th Oct, 2004 at 04:07:45pm
Edited by turbodave16v on 14th Apr, 2009. On 17th Nov, 2014 Tom Fenton said:
27th Oct, 2004 at 04:25:47pm
Lovely Job. I take it (for the price they are secondhand) you may as well get a pukka turbo carb (assuming the spindle seals/modulator ring are not available cheaply). Also, another stu-pid question, would the turbo inlet manifold fit over a Large Bore LCB? (No turbo!)
27th Oct, 2004 at 05:15:36pm
Stu,
27th Oct, 2004 at 05:41:35pm
since theyre are no stupid questions, ill ask one!!!
27th Oct, 2004 at 06:22:58pm
as i said - a 'starter'
Edited by turbodave16v on 27th Oct, 2004. On 17th Nov, 2014 Tom Fenton said:
27th Oct, 2004 at 08:08:05pm
Can get all the bits seperately but for the price of a rebuild kit its a peace of mind. if the bearings are shagged it wont show up as much on a NA but once the pressure is going in the other directions out pisses fuel |
27th Oct, 2004 at 10:01:20pm
Cheers Dave.
9th Feb, 2008 at 10:27:39pm
Found out my 1275 road mini (na) has a 1.5" hif, so went to fit a spare 1.75 hif and found it had a 4 and a 5 on it...(see TD's diagram above)
12 Posts Member #: 234 Member |
12th May, 2023 at 01:51:42am
Old thread I know, but has someone got a copy of Dave’s pic?? I use to have it years ago but can’t find it… |
just above the nice hot turbo
