Page: |
Home > Technical Chat > oil pump question | |||||||
508 Posts Member #: 487 Post Whore westbury, wiltshire |
9th Mar, 2009 at 07:01:05pm
how long should it take on average for the oil to come out the block outlet when cranking over with plugs out
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
9th Mar, 2009 at 08:08:32pm
about 15 20 secs always looking for them bigger bunches of bannanas |
209 Posts Member #: 6451 Senior Member South East Northumberland |
14th Jul, 2014 at 07:33:48pm
Just finished my first engine (re)build. After carefully stripping and reassembling, it started first time .
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
14th Jul, 2014 at 08:26:51pm
I always pack a new pump with Vaseline(not grease) as this helps it to prime on startup.The Vaseline just dissolves in the oil afterwards. |
1030 Posts Member #: 1291 Post Whore Suffolk / Birmingham |
14th Jul, 2014 at 09:14:44pm
Sure you have the O-Ring in the gearbox/block joint? |
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
14th Jul, 2014 at 10:45:16pm
Back filling is what I did. If something is worth doing, it's worth doing half of. |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
15th Jul, 2014 at 01:17:55am
Cam lube in the oil pump and back filling, almost instant oil pressure from a new engine. Back filling alone should work okay though. On 26th Jan, 2012 Tom Fenton said:
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
15th Jul, 2014 at 06:24:23am
I just oil the pump before fitting and back fill done properly you get oilpressure the same as you would if the engine has already run Yes i moved to the darkside
15th Jul, 2014 at 06:35:36am
I did fill my pump with build lubricant too. If something is worth doing, it's worth doing half of. |
15th Jul, 2014 at 07:41:22am
as above
15th Jul, 2014 at 07:54:05am
Yeah i built my oil pressure without plugs. I usually like to do it before the engine goes into the car but it means draining and refilling the oil with pot joints. If something is worth doing, it's worth doing half of. |
15th Jul, 2014 at 08:15:42am
ive got the frame out so will have it all built up suspension and the rest just drop the body over it when its time for me
15th Jul, 2014 at 08:21:48am
slater - yes I put the O-ring in, between the gearbox and the block. I did notice when fitting the paper gasket that the hole at this location was smaller than the O-ring, so fitted the O-ring into the recess then the paper gasket (the three gaskets for the block/gearbox in the engine gasket set threw me for a bit until searching on here) with instant gasket to locate the gaskets.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
15th Jul, 2014 at 08:26:03am
Do you have a pressure guage? Are you sure its not just a dodgy switch? Or! I have seen the wrong connector(usually the oil temp) plugged onto the oil switch. On 26th Oct, 2004 TurboDave16v said:
15th Jul, 2014 at 08:34:19am
could have a problem about that o ring being on the gasket as it may suck air
15th Jul, 2014 at 09:36:00am
Sprocket, I had wondered if the switch was U/S, hence my observation about the oil level.
16th Jul, 2014 at 11:37:47am
I'd be concerned about the O-ring not having contact with the metal faces on both sides. |
16th Jul, 2014 at 11:56:47am
I always use plenty of gasket sealant around that area, prevents problems arising. On 26th Jan, 2012 Tom Fenton said:
16th Jul, 2014 at 08:18:34pm
Engine pulled, pump filled, reassembled and put back in.
4890 Posts Member #: 1775 Post Whore Chester |
16th Jul, 2014 at 08:53:48pm
I just filled mine with assembly lube I run a supercharger and I don't care the TB is on the wrong side.
17th Jul, 2014 at 08:09:49am
using liquid gasket sealant it asking for trouble in my opinion!
17th Jul, 2014 at 10:17:21am
Never had a problem with the stuff as long as you're careful with application, prevention is easier than cure! On 26th Jan, 2012 Tom Fenton said:
20th Jul, 2014 at 02:43:38am
Engine running :)
20th Jul, 2014 at 08:09:44am
sweet as well done cant wait till ive sorted all the problems with mine and get it together |
Page: |
