Page: |
Home > A-Series EFI / Injection > Fuel System | |||||||
13th Feb, 2009 at 09:18:22pm
We are planning on using a Low Pressure feed to a swirl pot and then a High Pressure system local to the engine.
13th Feb, 2009 at 09:33:00pm
I would plumb in the return to the tank, my mate has exactly the same set up in the mini which he's building and he's been having no end of problems bleeding the system. Isambard Kingdom Brunel said:
4559 Posts Member #: 786 Post Whore Bermingum |
13th Feb, 2009 at 09:37:29pm
13th Feb, 2009 at 09:41:59pm
i say return too, On 28th Aug, 2011 Kean said:
152 Posts Member #: 1074 Advanced Member Northamptonshire |
13th Feb, 2009 at 09:42:30pm
Yes definitely return to the tank.
13th Feb, 2009 at 10:03:42pm
Thanks guys.
13th Feb, 2009 at 10:17:09pm
I like putting a filter pre HP pump. I have seen a few pumps fail with debris in new installations (tanks/swirl pots etc)
13th Feb, 2009 at 10:19:57pm
Definitely run the return. Any air that finds its way in the surge tank won't be able to escape otherwise.
3588 Posts Member #: 655 Post Whore Northern Ireland |
14th Feb, 2009 at 12:16:59am
the swirl must always return to the main tank, exitting high up from the swirl.
Page: |
