Home > 998cc > 1098, loads of questions
Advantage
Member #: 1450
Near Paris - France
After breaking my gearbox on the 998, I had a search for an engine and I found a 1098.
1098 sounds cool because I can build a higher comp engine in a "no head skimming" engine (I have a 12G295)
Can I get information such as diff ratio and compression with the engine number ?
Will the standart 1098 piston withstand 8 to 10 PSI ? (assuming an IC is fitted and 8.7 to 9 compression ratio)
Regards
Rusty by nature
http://www.guess-works.com/Gearbox/Technic...P2=&P2S=&EN_NO=
that will tell you the diff ratio for the engine number unsure if that will tell you CR but a google search should reveal all.
Advantage
Member #: 1450
Near Paris - France
Cheers for the link
Apparently the engine code I have been given is not in the list (791). Anyway all of them have a 3,44 diff which will be too high when turbo is installed ...
Oups, and I forgot about the pre-verto vs verto clutch => does this have a link with the pre-engaged starter motor ?
Rusty by nature
Advantage
Member #: 1450
Near Paris - France
Obviously gearbox on the 1098 I found is also pre A+
Gearbox also changed with the A+ engine including a gear selector shaft quite smaller (14 vs 18 mm).
Am I looking for trouble fitting this gearbox ?
Because if the 1098 road is only good if you convert a full A+ 998 and, according to my power calculator, only worth a mere 6 bananas at 10 PSI over a 998 (because the valve area to capacity ratio is not as good), I think it is not worth the hassle ...
I thought 1098 was a good way to build a higher comp engine without touching the head but pistons for 1098 don't seem to have decent CR ...
Rusty by nature
