Page: |
Home > A-Series EFI / Injection > sizing throttle body | |||||||
9th Jan, 2009 at 04:20:39pm
how do you go about sizing a throttle body? there has to be a balance between airflow and throttle control so biggest cant be best? Crystal Sound Audio said:
9th Jan, 2009 at 05:00:00pm
Well, I believe other factors like if there is a compund lever on the TB linkage should be considered as well. I have a BMW (i think) TB at 65mm that has a brilliant compounding ratio - the last 25-35% or so of opening takes just 3mm of pull on the cable. The first 25% of opening takes something like 4 times this amount.
9th Jan, 2009 at 05:29:55pm
lol,
10th Jan, 2009 at 10:08:35am
The one I got for the Mini project (at 1360cc) is a 54mm Rover one.
30 Posts Member #: 1466 Member Croydon / Derby |
20th Feb, 2009 at 08:31:56pm
Im currently building an engine using 2 single Jenvey TBs. I sized mine using flow area.
20th Feb, 2009 at 08:36:41pm
Are you using the Jenvey TBs for a turbo setup? Which ECU are you planning to use? And are those the single or dual injector TBs?
20th Feb, 2009 at 08:49:01pm
I hope to use it for turbo eventually, but as its a uni project and i ahvnt got much time its going to be NA for now. Ill be using a VEMS unit. Im planning to have one injector per runner, mounted on the runners themselves. So only two.
20th Feb, 2009 at 11:54:23pm
You are aware that the VEMS doesn't have an option to do port injection on the Mini engine, right? You may be able to make the engine run with it but it will be a compromise at best.
21st Feb, 2009 at 12:48:31am
oh yeh of course lol, ive done plenty of reading on the subject for a while now. If i was going to port injection then i wouldnt be using VEMS. I havnt just thought im going to inject the 5 port and gone ahead thinking its gna work with the siamese ports.
21st Feb, 2009 at 10:33:03am
Jean's point is that as you have decribed it above "two throttle bodies" and "one injector per runner", that is essentially port injection.....
Edited by Rod S on 21st Feb, 2009. Schrödinger's cat - so which one am I ??? |
21st Feb, 2009 at 12:07:23pm
hmmm i see your point now.
21st Feb, 2009 at 12:15:43pm
The problem is that the injector fires over a percentage of the engine cycle. At low load this may be less than 25%, or 180 degrees of the cycle.
21st Feb, 2009 at 12:33:20pm
Don't forget that even if you try to make it more akin to wet manifold than port injection by putting the injectors as far away as possible and pointing in strange directions, the siamese "problem" exists with carb(s) or single point injection anyway.
21st Feb, 2009 at 07:15:48pm
Ok, i understand what your saying, and im not taking it the wrong way lol, i understand that u were probly just warning me incase i thought that i could simply port inject and map as normal without taking into account charge robbing.
21st Feb, 2009 at 07:31:28pm
That's good.....
Page: |
