| Home > 998cc > MINI 998 TURBO | |||||||
9 Posts Member #: 4468 Junior Member Mytchett, Surrey |
3rd Dec, 2008 at 10:07:05pm
hi all
MINI: BENDS THE RULES, RULES THE BENDS!! |
3rd Dec, 2008 at 10:30:00pm
You don't need a 295 head (although that is what Paul & myself are planning on using) Wil & Ben have got a 940 head one of there 998 Turbos. As to where to get one, try the normal places, auto jumbles, eBay etc, remember the 295 head was also used on the MG Midget & the MG 1100 so it often pays to keep an eye out for MG heads.
4th Dec, 2008 at 09:38:19am
You will need the 12G295 if you are planning on retaining the standard flat topped pistons.
Edited by Paul S on 4th Dec, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Dec, 2008 at 09:43:37am
yea i think thats best, i going to go with megajolt for now and wen theres any advances on the megasquirt i will give it a go.
4th Dec, 2008 at 09:49:10am
Yes you could drop the CR by using the standard head and having (say) 6cc dished pistion. But to go to all the effort of turboing and keeping the crap 998 head seems a waste to me.
4th Dec, 2008 at 06:14:14pm
thats true, the only reasons i said that is i have been looking for a head which no luck but i can buy pistons off the shelf, but i have possibly found a head now. is there an uprated 998 head that you can buy that wont affect the CR?
4th Dec, 2008 at 06:19:06pm
if your planning on going megasquirt at a later point you may as well fit it now and just use it for the igntion instead of the megajolt as the jolt is just a cut down megasqurt really. On 28th Aug, 2011 Kean said:
4th Dec, 2008 at 06:38:38pm
On 4th Dec, 2008 mini_yom said:
thats true, the only reasons i said that is i have been looking for a head which no luck but i can buy pistons off the shelf, but i have possibly found a head now. is there an uprated 998 head that you can buy that wont affect the CR? im thinking of getting forged pistons anyway, because i want to strenthen everything before the turbo. o yea im looking to get between 100-120 bhp out of this, is it doable or am i dreaming, ive seen the figure 12psi boost out there and think it can be achieved? You need to drop the compression ratio for a turbo. If you use a 12G295 that has not been skimmed and flat topped pistons, you get around 9:1 compression ratio, which would be ideal for 12psi if you use a good intercooler. You do not need forged pistons for 12 psi. They would be a waste of money, even if you could find any. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Dec, 2008 at 07:29:13pm
Yes as Paul says a lot of 295 heads have been well skimed as they are often thrown onto non-cooper engines, therefore you wont get the CR drop that you want. But I take it you can still get hold of unskimmed examples then? On 7th Nov, 2008 Nic said:
6th Dec, 2008 at 05:42:09pm
what sort of power would i get with 12psi do you estamate???
6th Dec, 2008 at 05:56:59pm
not sure on the power, but yes a standard cam is probably best.
520 Posts Member #: 2093 Post Whore Grenoble, France |
6th Dec, 2008 at 06:30:57pm
as for the head, as i understand it you have to drop the compression ration for the turbo. could this be done with dipped pisons rather than the head change? it sounds easier plus i could source the parts easier from mini sport, but would the standard head with uprated head gasket be up to the task of the turbo? cheers I also wanted to try the std 998 head on turbo and I did the test for you :) No way. I've probably spent 200 euros on this std 998 Metro head (unleaded and seats a bit larger) and nothing, disappointing. My car is here: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=222687 However I'm still convinced that on 998 the 295 head is better than 1300 heads because they give a better resistance to knock, which means better overall efficiency. I recently bought a 295 for $75 but the car is 9000km away from here. Edited by alpa on 6th Dec, 2008. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
6th Dec, 2008 at 06:42:13pm
On 6th Dec, 2008 mini_yom said:
what sort of power would i get with 12psi do you estamate??? also am i correct that standard cams would be the best for everyday use? or do i need better ones. I asked same questions some time ago :) The answers I got and the cars present on this forum indicate you can easily get 100hp at 12psi, with intercooler of course. As already said you don't need forget pistons, spend your money on the gearbox and clutch. Std cams seem to be good for an everyday car. But the power band goes up to about 5000 RPM, it's low. I'd like to try a 266 cam, I liked MD256 on my N/A 998 but I'd like to have a turbo reving up to 7000. SW5 has too much lift. Look at this, this is with std 1.3:1 rockers
6th Dec, 2008 at 07:09:49pm
The MG metro cam is best IMO.
6th Dec, 2008 at 07:11:34pm
On 6th Dec, 2008 wil_h said:
The MG metro cam is best IMO. It gives great flexability and on the hillclimber 7k rpm is easy. Would you have the cam profiles ? std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
6th Dec, 2008 at 08:31:18pm
cheers guys i think i will go for the 295 head with n/a metro cams.
6th Dec, 2008 at 08:36:12pm
That's the way I'm going, MG Metro cam, 295 head.
6th Dec, 2008 at 08:53:21pm
cheers vegard very good to know!!
7th Dec, 2008 at 03:32:55am
Is the MG Metro still sold brand new ? I'm a bit scared to buy a used one on ebay.
7th Dec, 2008 at 11:29:20am
It seems as the factory Rover cams are very good. I'm very dubious to used cams as well, but the Kent range are ALWAYS more worn than factory cams. That's my experience.
7th Dec, 2008 at 11:45:13am
The Kent 500 cam is the MG Metro equivalent. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
7th Dec, 2008 at 12:38:47pm
Surely the reason the Kent (etc,) range wear more is because they are all regrinds from an original factory cam and so,
7th Dec, 2008 at 08:47:44pm
As above it's the Kent 500, spec below. Ive used both a Kent 500 and secondhand MG can and had no worries.
11th Dec, 2008 at 12:16:58pm
cheers guys
11th Dec, 2008 at 01:10:21pm
Don't bother with the metro turbo set up it is not worth the trouble. The normal mini front disk setup is perfectly capable of stopping any mini. Just get good quality disks and pads. You can upgrade the calipers to 4 pots if you like. http://www.twin-turbo.co.uk
