Page: |
Home > A-Series EFI / Injection > Thinking of Going to MS-2 | |||||||
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
24th Nov, 2008 at 10:37:13am
Ive been reading up on this MS lark and fancy having a dabble.
24th Nov, 2008 at 10:59:02am
First the easy point - why keep the EDIS ???
24th Nov, 2008 at 11:02:15am
Im a complete novice with this, ill just drive the coilpack direct then, i currently have a megajolt installed on it, but ill be puting this on my Cooper S.
24th Nov, 2008 at 11:04:43am
These are fitted to a 1380
24th Nov, 2008 at 11:08:36am
No reason why you cannot use throttle bodies that we know of. Injecting into the turbulent air just downstream of the throttle may have some interesting affects. Probably a little less fabricating to do.
1849 Posts Member #: 672 The oversills police Oslo, Norway |
24th Nov, 2008 at 11:09:31am
if I am correct then those pics are from the canems site. Have a detailed read on that page, as it describes the problems with injection on a siamese inlet port head. |
24th Nov, 2008 at 11:11:13am
Or start here..
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
24th Nov, 2008 at 11:13:18am
i am planning efi (with turbo later) on my mini for some time now, i have been reading as much as i can find, i need to read more , i am keeping my eye on this thread, :)
Yes i moved to the darkside
24th Nov, 2008 at 11:16:18am
When reading other site they all seem to be written by experts for experts. Theres no spaz guide, which is what i need. Hmmm Cam sensor? How the hell would you do that. Theres a good article in Mini Mag that i keep referring to by Canems, and its on a 1l mini. They just use 2 Widebands 1 on the outer one on the inner.
24th Nov, 2008 at 11:24:20am
The dual widebands are for testing purposes only. Once turboed you will be on a single wideband.
24th Nov, 2008 at 11:27:45am
On 24th Nov, 2008 MikeRace said:
They just use 2 Widebands 1 on the outer one on the inner. Could i not just do this?? Not with a turbo - at least not according to the LSU specifications - they don't work pressursed and would cook anyway. They have to be after the turbo so you're down to one pipe... I'm doing the same as Paul and setting the engine up N/A first with dual widebands (actually three in my case) to try to get the data to prove a siamese (or similar) code for MS will deal with the charge robbing. EDIT - Paul beat me to it, I type too slow..... Edited by Rod S on 24th Nov, 2008. Schrödinger's cat - so which one am I ??? |
24th Nov, 2008 at 11:33:51am
Right on, ill hang about then i recons. I have thought about sticking it on My S however,
On 24th Nov, 2008 Paul S said:
The dual widebands are for testing purposes only. Once turboed you will be on a single wideband. With respect, if you do not understand the issues of charge robbing, then best leave it a while until someone has a system working and the pitfalls are fully understood, otherwise, you could spend a lot of cash and get nowhere. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
24th Nov, 2008 at 11:51:09am
I'm running the Siamese Code on my 998 at the moment in NA mode.
24th Nov, 2008 at 01:16:14pm
Whats the crack with the cam sensor then? Doesnt the MPI use one? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
24th Nov, 2008 at 01:21:50pm
The ECU needs to know which part of the engine cycle, No. 1 piston is on so that it can time the injection. Hence it needs a cam sensor.
Edited by Paul S on 24th Nov, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Nov, 2008 at 01:23:35pm
I see, what stage are you at with this. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
24th Nov, 2008 at 05:24:22pm
I would say that we are nearly there.
4559 Posts Member #: 786 Post Whore Bermingum |
24th Nov, 2008 at 07:22:07pm
24th Nov, 2008 at 07:26:55pm
On 24th Nov, 2008 Bat said:
Hi, You could always use a single throttle body on an SU type of manifold? Cheers, Gavin :) You may as well set light to fivers IMHO. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
24th Nov, 2008 at 07:42:51pm
You may as well set light to fivers IMHO. LMAO!
Page: |
