Page: |
Home > FAQ / Knowledge > Calling all welding experts! | |||||||
82 Posts Member #: 2675 Advanced Member Isle of Man |
31st Oct, 2008 at 11:33:12am
Hey guys,
"If i'm not in action...i'm in traction" |
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
31st Oct, 2008 at 11:47:49am
You may have too much gas flow there ny friend. Other than that your getting contamination from some where have you tried warming the metal first? Own the day
31st Oct, 2008 at 11:57:09am
On 31st Oct, 2008 r1_manx said:
The first is the galvanised pipe, after sanding it back to steel (as opposed to zinc) it is still contaminating the weld and there's a white smoke/powder forms around some sections of the weld. Weld tends to contain voids. I guess this is just tiny traces of the zinc left after sanding? Zinc - white powder is the giveaway. You may have to be more aggresive than sanding ie, grinding, to remove it all. On 31st Oct, 2008 r1_manx said:
*Clean mild steel. Some welds are fine, exactly as expected, neat fishscales then others on the same material form numerous small voids that wont close up or if they do end up as hidden bubbles in the weld. As you ramp the current down the final bubble often grows as it cools into a sort of hollow boil on the surface of the weld (as opposed to the more normal shallow depression and small pimple). Oxidation of the molten weld metal. Usually from contamination (NOT from inadequate shield gas flow with these symptoms) and usually coming from the back of the weld, ie, the inside of the pipe is dirty or the gap at the back of the weld is too big. Can be poor filler wire - is it proper TIG wire you're using ??? Gas filler wire is NO GOOD for TIG. It should have the BS/EN number and the grade on two small flats at the end of the wires if it's proper TIG wire. But more likely contamination or air from the back of the weld. Are you, for example, welding up a closed tube ??? If so, the heat of welding expands the air in the tube and blows contamination (and air) through your molten metal. Each tube should ideally have a small hole drilled through its wall near where the welds will be. A high integrity weld would require a small flow of argon inside the tube as well as the argon from the torch to stop this. There are many other possibilities, but those are the obvious ones. Also I would be using at least a 2.4mm filler wire for that size material and that current. Having too small a wire for the size weld pool won't help, and the current sounds quite high for that size tube. Final thought - correct tungsten (thoriated) and proper angle ground on the end - the zinc will kill the end of the tungsten in no time at all.... EDIT - just noticed, you don't say what size tungsten... I would be using a 2.4mm on that size pipe and that high a current. Edited by Rod S on 31st Oct, 2008. Schrödinger's cat - so which one am I ??? |
122 Posts Member #: 2023 Advanced Member nr Portsmouth ,Hampshire |
31st Oct, 2008 at 12:40:47pm
make sure to wear masks when welding galvinized tube as the fumes given off are not good for you |
628 Posts Member #: 1064 Formally Whyte_ben Horndean, Hampshire |
31st Oct, 2008 at 12:54:30pm
On 31st Oct, 2008 5portsrock said:
make sure to wear masks when welding galvinized tube as the fumes given off are not good for you Very true, my mum cooked at a bbq a while back, the prick who's bbq it was got the bbq grill gavanised and my mum ended up in hospital for 2 days from the fumes.
31st Oct, 2008 at 01:08:29pm
Thanks for all the advice so far guys very helpful. I have spoken to my mate James and he has this in reply:
Forum Mod 5933 Posts Member #: 784 9 times Avon Park Class C winner Milton Keynes |
31st Oct, 2008 at 03:13:41pm
Bring the gas flow down to 8 l/min, should stop the holes forming and give a neater weld
I seriously doubt it! |
31st Oct, 2008 at 03:15:51pm
are you sure its the right tungsten? On 28th Aug, 2011 Kean said:
54 Posts Member #: 8863 Advanced Member Wiltshire |
20th Apr, 2010 at 08:08:32pm
Sorry to bring up old thread but may help others. The higher gas flow as a few others have said will cause big problems with weld quality. When you go too high turbulence occurs and you end up pulling air into what should be, inert atmosphere.
549 Posts Member #: 5327 Post Whore Dudley, West mids |
20th Apr, 2010 at 10:43:35pm
Get yourself a small pieced of titaium. This will show up any problems with your gas and flow. I weld anything from titanium, nickel alloys, aluminium, stainless, colbalt, carbon steels and have my gas set to 14lpm. My equiptment is calibrated every 6 months and is aerospace verified.
25th Apr, 2010 at 07:51:27am
Madcat, I guess 14lpm could work fine but will depend on shroud size. if you have a nice big diameter shroud then no problem. if your using very small diameter shroud (most tig kits supplied with these) then 14 would be too high imo and cause probs.
25th Apr, 2010 at 06:24:50pm
Oh yes good point. I use a wide ceramic. A wide ceramic is best all round if gas usage is not a problem. Also tungsten projection (amount the tip of the tungsten stands proud of the ceramic) I'll take a photo of my torch while I'm at work tomorrow and post it on this thread. |
Page: |
