Home > Technical Chat > piston ID,
any one know waht these are out of,
they look low comp,
21268 G8 LO7
I have a set of these.
They came out of an engine that I bought as an MG Metro engine. It had all the right bits for the MG engine except it had a standard cam.
They have a largish dish, but they have the maximum compression height so come close to the deck.
yes Paul , i don't remember seing this type before,. small slott for oil, drain , but fully circular around the pin bore on the sides,
I thought that they were 9.75:1 compression, but not sure now you have pointed out the large dish.
its factory A+ piston 1980 to 1984
rob620
Member #: 10537
Did anyone find out the dish size of these pistons and what compression ratio they run standard? Im looking to convert a n/a engine with these pistons into a turbo motor running around 10psi and need to know the dish size etc so I can work out a suitable comlression ratio. My pistons are marked 21268 g7 L33. Would really appriciate some help on this :)
There not the ones I gave you to slot are they haha
rob620
Member #: 10537
Ay? Sorry didnt get that haha
