Home > 998cc > broke actuator
blister
Member #: 2590
Croydon
my actuator i got with my turbo has got massive holes in it all the way around and i cant find any where to get one that is a standard item does any one have one or no somewhere
i heard you can put any turbo actuator on any turbo is this true?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Actuators are all very similar. You can't strictly use any actuator but if you can get rod lengths equal and get it mounted on the bracket then your done. Just make sure the actuating pressure is suitable to your needs as actuators have different pressure ratings
On 30th Apr, 2010 Rod S said:
Gary's description is best
What turbo is it?
Most actuators are interchangeable to a degree, but the are rated for difference amounts of boost.
ive got one you can have for £10
blister
Member #: 2590
Croydon
the turbo is from a renault 5
blister
Member #: 2590
Croydon
will a actuator from a t3 work?
No reason why it won't, you'll need to make up a bracket though.
