Home > A-Series EFI / Injection > MAP Sensor
Does anyone have a list of cars that where fitted with MAP sensors as standard? Looking few the small collection of Haynes manuals I've acquired most cars seem to have MAF sensors instead, and I'd like to avoid having to go round checking under bonnets for a sensor that may or may not be there.
Edited by Rob H on 16th Aug, 2008.
most boosted engines use map sensors, type map sensor in to ebay then target the cars that ebay lists when u go to the wreckers :)
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Nearly all the VAG engines 1.6l and under are MAP. They would be your best bet if your going to a scrappy because they are shit engines so they will be abundant.
Most of the bigger VAGs are air mass.
Ford mostly use air mass.
Toyota always use MAP.
Renaults usually use MAP.
Avoid BMW and Merc as they never use MAP.
They are just random ones that stick out in my mind. If I can think of anymore I'll post them up
On 30th Apr, 2010 Rod S said:
Gary's description is best
evolotion
Member #: 83
Glasgow, Scotland
rovers are always map *wink*
Denis O'Brien.
Cheers guys, got a Honda one (made by Denso) in the end just need to work out which wire is which.
Arse, stripped a few bits of a metty for my mates 16v Rover K-Series project and didn't notice.
A simpler question might be....what do you need the map sensor to do ?
Then we can suggest where to look.
Saab MAP sensor 250 kpa, picked the last 2 up off ebay less than a £5 each *wink*
Down Bristol way too iirc.
I'll find out the part number...
alpa
Member #: 2093
Grenoble, France
Almost all engines with variable valve timing VVT use MAF. Also all diesels, as they usually don't have throttle.
Alfa use MAF (VVT). Fiat/Lancia use both, depends on the engine.
