Page: |
Home > Help Needed / General Tech Chat > New Engine spec | |||||||
![]() 48 Posts Member #: 349 Member Lutterworth |
9th Aug, 2004 at 11:55:42pm
Hi I have never owned a turbo mini before and am new to this site, |
10th Aug, 2004 at 08:44:24am
This is pretty much a well known spec that does the job: (cut/pasted from another post)
Edited by TurboDave16V on 10th Aug, 2004. On 17th Nov, 2014 Tom Fenton said:
10th Aug, 2004 at 10:49:06am
That engine spec sounds good.
10th Aug, 2004 at 12:48:33pm
yep, but also pulling out all the core plugs and removing any casting flash that may be impeding coolant flow... On 17th Nov, 2014 Tom Fenton said:
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
10th Aug, 2004 at 05:25:19pm
use a deep cast impellor water pump 2 core rad 6 blade fan oil squirters under the pistons to keep them cool, cross flow water cooling ,ceramic coatings on everything that gets hot , tubular exhaust manifold ,fuel injection etc etc
10th Aug, 2004 at 08:13:38pm
Thanks for that dave I have a budget of 3 grand for the engine and box so, do you think there are any other things that could be upgraded for that money,
10th Aug, 2004 at 08:16:22pm
one last thing which re-mappable ecu do you advise using and is it possible to run throttle bodies
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
10th Aug, 2004 at 08:38:15pm
I run the Emerlad ECU, dave one DTA, both do pretty much the same job, It's really down to what rolling roads you have near you, and which system they know best.
Page: |
