Home > Technical Chat > Rear Wheel Bearing
longy
Member #: 2727
Bicester
Hi Guys, i need to replace the rear wheel bearings, at the moment they are the ball bearing type, apparently this type has been discontinued, will the taper type fit my hubs?
Thanks
1972 998 TURBO SLEEPER
miniminor63
Member #: 672
The oversills police
Oslo, Norway
yes
As above, yes, and they are better too.
longy
Member #: 2727
Bicester
Thanks guys
Thread dig up !
Are the taper bearing still the preferred choice rather than the ball bearing ones !
graemec
Member #: 1424
Carnforth, Lancs
You'd be lucky to find the ball bearing ones. The tapers should be better though.
There's seams to be loads of ball bearing ones available graham !! But not many taper !
I would of thought the ball bearing ones were the updated n preferred version of the taper to be honest !
graemec
Member #: 1424
Carnforth, Lancs
where at - I wanted ball bearing last time and couldn't find them anywhere....
https://www.minispares.com/product/Classic/...ack%20to%20shop
graemec
Member #: 1424
Carnforth, Lancs
They're taper roller - first three words of the description *wink*
http://www.minisport.com/ghk1548-mini-rear...-1959-2001.html
What's the difference between these then .
It'll teach me to read things next time . So I gather there both taper but ones rollers and other balls !
graemec
Member #: 1424
Carnforth, Lancs
Both roller - probably no different apart from manufacturer maybe.
The MiniSpares ones look different as they've shown the inner element and the race together rather than split apart.
PhilR
Member #: 10034
Birmingham
Same part number GHK1548 (roller bearing),
same manufacturer (GHK).
EDIT - although, reading some other forum posts, I wouldn't be convinced that certain retailers would use a different part number if they managed to source a cheaper, non branded alternative. I'd be wary of a good deal on Minisport despite them using the GHK part number.
Edited by PhilR on 2nd Nov, 2015.
