Page: |
Home > FAQ / Knowledge > How to make an SU piston lift indicator | |||||||
14th Jul, 2008 at 12:03:19am
In my recent quest to polish the perfect needle I realised I needed to be able to see the position of the needle at all points of drive and with a turbo that has a pressurised piston chamber thats not easy.. So I came up with this, Its pretty cheap and works well.
Edited by Turbo Tel on 14th Jul, 2008. website:- http://www.terryhunt.co.uk
14th Jul, 2008 at 12:03:38am
First drill a hole same size as the ally wire in the cap of the dashpot piston that aligns with the top surface of the piston shaft (the bit you put the oil in) make sure its aligned properly. The cap pretty much shows you where to drill as the shaft goes right up iinto it and the plastic is grooved to take the shaft, just drill in the groove.
14th Jul, 2008 at 12:22:27am
Next, you can apply the paper position scales to the tubing.
Edited by Turbo Tel on 15th Jul, 2008. website:- http://www.terryhunt.co.uk
14th Jul, 2008 at 07:29:44pm
Cooooooool!
553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
23rd Nov, 2015 at 07:35:32pm
I would like to make one of these, but one that i could see when i was driving along. Im thinking maybe some kind of potentiometer connection to the rod and a digital read out in the car. Not sure how to execute the mechanical connection to a pot, any thoughts? |
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
23rd Nov, 2015 at 08:10:22pm
done years ago, why does it have to be a pot?
Yes i moved to the darkside
23rd Nov, 2015 at 08:18:58pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=159683
Edited by Brett on 23rd Nov, 2015. Yes i moved to the darkside
23rd Nov, 2015 at 09:11:34pm
On 23rd Nov, 2015 Brett said:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=159683 also page 19 of my build thread Yes can see how you have done that. Dont recognise the device you are using to convert movement to electricity, is it just a variable resistor? Maybe i will try some kind of cable arrangment and feed the end of it inside the car and have some kind of scale on the end i can read while driving |
24th Nov, 2015 at 06:01:42am
Yeah a slide type variable resistor Yes i moved to the darkside
Page: |
