Page: |
Home > A-Series EFI / Injection > ECU / EMS water temperature sensor | |||||||
![]() 5988 Posts Member #: 2024 Formally Retired Rural Suffolk |
28th May, 2008 at 09:34:09pm
Two questions really...
28th May, 2008 at 10:13:42pm
You wont ever find published scaling for the Lucas sensor, it just doesnt exist
29th May, 2008 at 09:20:37am
Thanks Sprocket, if you can find the data you measured for the Lucas one, that would be most helpful.
29th May, 2008 at 09:32:05am
the rover sensor is a funny thread,
29th May, 2008 at 09:32:28am
I found with VEMS that most use Bosch sensors and there are several files already available for those. The lucas one compared to pretty much any of the bosch ones is a much shallower curve, so, if we overlay the data on a graph and have them crossing over in the middle, the lucas one reads high at low temp and low at high temp, thats if you were to use one of the bosch files. We are talking around 5 degrees in total
29th May, 2008 at 10:32:41am
Thanks Sprocket, I think I'll use Bosch, if only because all the information is readily available from their website, including thread size, and (mini13), if the lucas one is a less common metric fine, I don't want the hassle of trying to find a tap (at least M12 x 1.5 is relatively easy to source even though it's not standard M12)
Edited by Rod S on 29th May, 2008. Schrödinger's cat - so which one am I ??? |
29th May, 2008 at 10:55:50am
hang on,
29th May, 2008 at 06:27:33pm
yep talking crap,
29th May, 2008 at 07:04:06pm
No problem,
![]() 10 Posts Member #: 1539 Member Denver, Colorado |
18th Dec, 2008 at 05:30:21am
Just wanted to add in that I spent several hours today plotting the temperature vs resistance of the brown Elmwood ES120-4 used on the mpi motors and If anyone wants to see the data I have attached it.
Edited by dhaines on 18th Dec, 2008. "sorry, Jedi mind tricks don't work on retards" Mediocre Films 2008 |
18th Dec, 2008 at 06:44:21am
Actually, they use the Steinhart-Hart equation to establish the table of temperature vs resistance from the 3 points. You can read more about it here: http://not2fast.com/megasquirt/doc/thermistor.html.
18th Dec, 2008 at 05:24:56pm
Good call Jean. I redid my analysis to include the Steinhart-Hart equation and plotted the measured vs exponential vs steinhart on one graph. I also noted the resistance at 81 deg F which was about 100ohm between the exponential and steinhart, however the exponential was the same as the measured at this temperature point. I dont know which one I like more, the stein or exp. Mabye I can try and get some hotter and colder data. Edited by dhaines on 18th Dec, 2008. "sorry, Jedi mind tricks don't work on retards" Mediocre Films 2008 |
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
18th Dec, 2008 at 06:15:27pm
Interesting work. Struggling with degrees F though.
18th Dec, 2008 at 08:09:54pm
I messed up the graphs in the previous attachment. This one should be much clearer. I also plotted the log and exp against stein. The stein does a good job at getting the sensor data correct as it gets colder but on the hot side its mediocre.
18th Dec, 2008 at 08:37:46pm
The other thing to note is that the MPi sensor is still a NTC 2.5kOhm sensor, so the standard build Megasquirt resistor will be just fine. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
18th Dec, 2008 at 08:48:53pm
On 18th Dec, 2008 dhaines said:
Sorry for the Deg F, I guess I could have changed it but we still use it over here :$ Where are you based then "d...." ??? It helps to know when posting because of time differences if you are where I think you are :) Rod. Schrödinger's cat - so which one am I ??? |
18th Dec, 2008 at 08:58:19pm
Im over here in the US. Colorado-which is why I am going with the baro correction.
Sorry for the Deg F, I guess I could have changed it but we still use it over here :$ Where are you based then "d...." ??? It helps to know when posting because of time differences if you are where I think you are :) Rod. "sorry, Jedi mind tricks don't work on retards" Mediocre Films 2008 |
18th Dec, 2008 at 09:30:32pm
Im over here in the US. Colorado-which is why I am going with the baro correction. I guessed so.... sorry if my earlier comment was badly worded. I must stress that I am very much a "novice" in this so far so am relying on Jean and Paul for the initial work but am hoping to follow up with some of the testing - I've done a little with dual widebands on carb and dizzy so far but am way behind the rest - I have yet to weld up my fuel injection manifold/plenum/runners... I've got all the metal, but not the time :) Schrödinger's cat - so which one am I ??? |
18th Dec, 2008 at 10:39:13pm
I thought that the resistors on the board had to match the coolant sensor at 81F?? from the megamanual: "To avoid changing the tables in the MegaSquirt® code with EasyTherm, the bias resistors at R4 and R7 should have a value equal to that of the thermistor sensor you will be using when it is at 81° Fahrenheit, 27º Celsius. However, the preferred method is to use EasyTherm whenever possible. " I think that may be superceded with MSII/Extra. Besides it makes little difference in the temperature range we are interested in. Edited by Paul S on 18th Dec, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
