Home > FAQ / Knowledge > how to set the Actuator pre load
b12
Member #: 247
Kent/Surrey Borders
well
I am about to change my actuator
It all looks like it makes sense to me ;
When the actuator is on ; HOW do i set the pre load ??
Is it a case of turning the spindle in the actuator and setting the the lock nut at some predetermined postion
your 'in the dark'
steve
Edited by AlexF2003 on 5th Mar, 2006.
TurboLessTosser
its easy enough mate. have the arm off and the wastegate shut. Now screw the arm in or out till the hole in the end is 6mm short of going on the wastegate. This is called the "pre-load". some people run with a lot less but it does me.
Then just pop it on *smiley*
b12
Member #: 247
Kent/Surrey Borders
got the old actuator off
I have a Avonbar 8 psi actuator that i am gunna try ;;;;;; the threaded shaft is 1/2 mile to long .... I guess i am supposed to cut it ??????
TurboLessTosser
You shouldn't need to cut it, i didn't have to with my Avonbar actuator. It will screw quite far into the other half.
Phil. *smiley*
jamestar
Member #: 9159
Devon
Sorry for digging up and old topic, but i'm having some trouble and this topic seemed appropiate.
I've got a GT1752 and i've clocked the compressor housing.
How do i go about making a new bracket for the actuator to mount on so the pre-load is correct?
Edited by jamestar on 7th Feb, 2011.
scott the joiner
Member #: 9229
newcastle upon tyne
B12 I had to cut mine down as the threaded shaft was to long just make sure u don't go to short *smiley*
tadge44
Member #: 2500
Buckinghamshire
Depends how far you have clocked it I suppose, but I made a flat plate of quarter ally attached to the original actuator points shaped a bit like the bracket on a towbar to hold the lighting socket.
Have a look on Roberts thread on GT1752 to see how he did it.
jamestar
Member #: 9159
Devon
I've seen roberts, but yours sounds much more simple *happy*
Am i right in saying that if the pre-load has already been set, then all i need to do is make sure the actuator just about hooks onto the bracket and i shouldn't have any issues?
Do you have any pics of your tadge as i've never seen a towbar upclose :$
