| Home > A-Series EFI / Injection > Megasquirt VE map | |||||||
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
18th May, 2008 at 06:17:10pm
I am setting up Megasquirt soon with throttle-body injection using a GM TBI 700 body on a downdraft Weber manifold.
1275 with Back Door Turbo |
18th May, 2008 at 08:00:54pm
VE maps are specific to your engine and the injectors you use, unless ssome one has the same injectors as you, you will unfortunately have to start from scratch.
18th May, 2008 at 09:13:31pm
The injector characteristics are actually captured in a calculated injector pulse width. The VE table truly is entered in terms of % volumetric efficiency.
18th May, 2008 at 10:35:43pm
The standard Megasquirt map that came loaded on my ECU was actually from a small block chevy and seems very close to what needed for the A-series. When you consider the general design of the two engines, it's not hard to see why.
19th May, 2008 at 04:20:41am
Thanks, Paul. E-mail is wkever@comcast.net
19th May, 2008 at 05:15:56am
Paul is using port injection which is the equivalent of 2 squirts per cycle.
20th May, 2008 at 03:11:32am
With the throttle body that will fit the manifold, there is only one injector. To get the fuel flow needed under boost, said injector is a big boy, 85lb/hour.
23rd May, 2008 at 09:43:42pm
On 18th May, 2008 fortfun said:
The injector characteristics are actually captured in a calculated injector pulse width. The VE table truly is entered in terms of % volumetric efficiency. Certainly it will depend on the engine spec. Yep, Megatune has something built in. I'll probably use autotune as well, since I have a wideband. Just hoping to see some results others arrived at. The required fuel value does not take into consideration the requirements of your engine to produce power, so if you fit a larger injector than required for the expected power on a 1275 engine, the injector will not be used to its full potential, the required fuel value will be small, and VE values will be low. Same engine, but with a smaller injector correctly sized for the expected power, the required fuel value will be bigger and the VE values will be larger. The VE table is not VE of the engine. The required fuel value is only there to calculate the PW at full flow of the injector and is equivelant to 100%VE in the table. There is nothing to say that the engine is capeble of achieving power levels at 100%VE with the injectors installed. So, the VE table is specific to your engine and the size of injector you use. You could scale it down by the difference of percentage of flow rates between injectors as the shape of the table will be similar On 26th Oct, 2004 TurboDave16v said:
26th May, 2008 at 08:57:21pm
Thanks for the VE map, Paul.
26th May, 2008 at 09:19:09pm
Fortfun,
Edited by Paul S on 26th May, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th May, 2008 at 01:06:22pm
Im sure the VE is a % of the required fuel for the size injector used. By adjusting the required fuel your basically altering the increments of the numbers. The smaller the required fuel number the smaller each inrcrement is between numbers (finer tuning). If you have a req. fuel of say 4 but set it to 2 you will need double the value in each box in the table to give the same amount of fuel.
