Home > Show Us Yours! > Dump valve fitment
mg-metro-matt
Member #: 1870
Aldershot (we are top of the league, say we are...)
Have started fitting the dump valve bits to the metro turbo, i decided to go for a silicone T-piece rather than welding to the plenum, so the car is easily returned to standard, i blocked the o.e dump valve spring with a nut and bolt with copper washers, i have also used one of the modified carb spacers which have a vacuum take off for the dump valve actuator. Very handy but this meant that the outlet from the turbo wasnt inline with the plenum trumpet, which made fitting the plenum back to the carb a little awkward, thankfully i hadnt cut to much off the length of the t-piece and it has stretched over. Let me know what you think!
Ric
Member #: 36
Basingstoke
Not a bad way to do it as it's still close to the butterfly. Nice work.
Should do the job nicely!
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
had the same thing with mini try undoing Bolts and turning the housing that the filter comes off slightly then it will line up
redwing
Member #: 1574
Malta
Its always good to see people 'do something different'. Nice work.
mg-metro-matt
Member #: 1870
Cheers for the infor Alan, didnt need to in the end as the hose was long enough to stretch over the 2 outlets, heres a couple of pics of the dump valve fitted, it touches the rocker cover slightly but thats the only place i could get it to fit so i can live with that. I must say it works very well, im interested to know what difference putting it in the plenum makes? as it dumps everytime you take your foot off the throttle.
Edited by mg-metro-matt on 4th Apr, 2008.
can you not trim the silicone back a bit? also forgot to say looks good :)
Edited by Paul R on 4th Apr, 2008.
mg-metro-matt
Member #: 1870
cheers man, maybe could ever so slightly but the spout coming out of the dump valve is quite long
bernard
Member #: 2492
Devon
never thought of doing it like that ! I also I have a metro turbo which
I brought a few weeks back, were abouts did you get the modified carb spacer with vacum outlet? cheers
Avonbar or Minispares I think.
mg-metro-matt
Member #: 1870
yeh it was avonbar, make sure you get the longer studs with it though or it wont fit. A point to note is that it makes bolting the plenum back to the carb a little tricky as the turbo outlet no longer peferctly lines up with the plenum, i inserted the plenum into the pipe and then tightened the plenum bolts and it all pulled up ok. *happy*
turbomadf111
Member #: 9647
weston-super-mare
hi i havegot a mg metro turbo and i am trying to fit a bump value to it but it don't seem to be working can you please ring me 01934 707055 or 07832578068 or if not can you send me your number so i could ask for some advise on this, i would be very greatfull if you could get back to me, thanks dean.
Mate you know we have a Private Messenger setupon this site.
metroturbo
Member #: 989
North Yorkshire
He has long since sold his Metro and moved on to VWs, so he is unlikely to come here anymore.
