Page: |
Home > A-Series EFI / Injection > relucter sensor wiring | |||||||
22 Posts Member #: 2278 Member salisbury wiltshire |
20th Feb, 2008 at 06:06:40pm
does any one know which way the wies go ie what the polarity of the wires are and how do you find out which wire is positive |
4559 Posts Member #: 786 Post Whore Bermingum |
20th Feb, 2008 at 08:32:53pm
20th Feb, 2008 at 10:52:22pm
thanks im just getting around to converting me mini turbo from standard ignition with a luminition trigger to a megasquirt 2 controlled system. it was runing on an emerald cams system with a diy throtle body but the ecu was very troublsom |
20th Feb, 2008 at 11:07:55pm
20th Feb, 2008 at 11:10:34pm
cheers just got to put me crank sensor and me 3 point injection manifold back on and ile give it a try |
20th Feb, 2008 at 11:10:59pm
20th Feb, 2008 at 11:12:51pm
20th Feb, 2008 at 11:18:15pm
ile try and get some pics for you but basicaly ive got two injectors fitted into the inlet manifold and one injector fitted into a throtle body which uses the mounting flanges from a metro turbo carb and a aluminium sleve fitted inbetween them and the injector is fitted before the throtle body |
20th Feb, 2008 at 11:19:40pm
Page: |
