| Home > MS Trials & Testing > Megasquirt Injection Timing | |||||||
5th Jan, 2008 at 12:49:56pm
I'm investigating what the standard MS2/extra code does before I rip off the carburetor.
Edited by Paul S on 5th Jan, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
520 Posts Member #: 2093 Post Whore Grenoble, France |
5th Jan, 2008 at 01:44:30pm
Connect you signals to the micro laptop input through 10k pots. You'll get a 2 way scope, you'll be able to watch the reference and the injector signal.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
5th Jan, 2008 at 05:19:06pm
It would make sense that it's picking up the end of the pulse because that would correspond to the flyback voltage from closing the injector.
5th Jan, 2008 at 05:33:46pm
They are high impedance injectors.
5th Jan, 2008 at 05:47:57pm
The standard code just starts the injection after the trigger tooth for the ignition. It does all it's computations for the ignition time and dwell then starts the injection pulse.
3 Posts Member #: 10242 Junior Member |
16th Jan, 2013 at 08:32:46am
any one here |
17th Jan, 2013 at 01:22:09pm
@ newguy1,
