Page: |
Home > FAQ / Knowledge > Bearing shells | |||||||
4360 Posts Member #: 1459 En-suite user Braintree, Essex |
3rd Jan, 2008 at 09:05:27pm
Is there any prefered method of fitting main bearings shells etc? On 19th Jan, 2010 wil_h said:
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
3rd Jan, 2008 at 10:09:06pm
I prefer to use my fingers. On 13th Jul, 2012 Ben H said:
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
4th Jan, 2008 at 08:00:02am
Clean hands, and work station.
4th Jan, 2008 at 10:22:31am
lol
4th Jan, 2008 at 10:45:22am
Fit the caps and bolts before putting your shells and crank in. (with no bearings or crank) and check that there is no overhang on the inside of the cap, you can check by eye, but i tend to run my finger along the inside. (had probs with the lugs warping)
Edited by MikeRace on 4th Jan, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Jan, 2008 at 11:00:32am
This is a great book if you are building an engine. I use it every time.
4th Jan, 2008 at 11:17:35am
i'm pretty sure I have a copy of that book.
4th Jan, 2008 at 11:52:58am
Here is the way I do it, make of it what you will.
4th Jan, 2008 at 12:12:07pm
Cheers danboy, No secret methods then. Will get some gaskets Saturday and get the old girl back together. :) On 19th Jan, 2010 wil_h said:
4th Jan, 2008 at 12:22:58pm
On 4th of Jan, 2008 at 12:12pm milamber said:
Cheers danboy, No secret methods then. ) There might be but they would't be secret if I told you. lol Dave |
4th Jan, 2008 at 01:00:25pm
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
4th Jan, 2008 at 03:27:10pm
Good advice from Dave, the only thing I would add is that the area between the rear of the shell where it fits into the block should be spotless and dry. No not put oil here.
4th Jan, 2008 at 03:41:42pm
Plastigage is only used to check the running clearances. If the crank has just been polished or recut its a good idea to double check them.
4th Jan, 2008 at 04:08:13pm
Plastigage is great:
Page: |
