Home > Help Needed / General Tech Chat > "single point injection" on turbo engine
TurboHarry
Member #: 115
Austria, near Vienna
Has anyone ever tried a single point injection on a turbo engine?
(Of course not the Rover stuff; I am thinking about Emerald or Haltech ECUs)
I mean having one (or a stagged second) fuel injector placed before the inlet manifold didvides into the two inlet runners. To place the injectors there should eliminate the charge robbing problems that the twin point injectors run into.
(Similar to the carb setup - but only controlled and programable by an ECU)
I think all the Mini 5 port Emerald ECU users may have thought about this - what could the problems be with this setup?
Harry
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
TurboDave16V
Good Call Harry.
EFI spi is almost as hard to sort out as Mpi, simply because you can't get the fuel to be injected at the right time. The inection start/end point still moves wrt RPM, hence you still end up with charge stealing on most propietry aftermarket ECU's.
If an ECU was developed that allowed you to configure the two injection point 'boundaries' per 360 crank degrees, and then had a 'second' correction map to shift both these points acording to RPM, the problem would be solved.
Now the challenge is to find someone to do this!
TurboHarry
Member #: 115
Ever thought of fitting 4 injectors (2injectors per port runner) that are controlled to inject fuel eg. 50? before the appropiate inlet valve opens? This would cure the "right time" problem. The amount of fuel would be controlled in the usual way by the length of injector opening. Of course this would mean, that there would be an overlap of spraying per port. (Because of this "very well designed" charge robbing layout. *smiley* )
Do you think this could work? Or would there still be unequal fuel distribution?
TurboDave16V
For me, two high impedance 'modern' injectors per inlet tract is the only way to do it...
You still need to be able to set the injection point, and may run into problems at higher rpm with charge stealing (unless you are able to shift the injection point).
Definately the right way to go though...
For some unknown reason I was thinking about this whilst cycling home in the rain this evening and was wandering is there any reason why on an SPI set up the injector only fires once per cycle? Could you get more even fuel distribution if the injector fired say four times per cycle? obviously this is a bit irrelevant now that sequential port injection has been cracked but it's taken me four years to get my head round this.
jbelanger
Member #: 831
Montreal, Canada
That's the only way to get a half decent result.
Jean
http://www.jbperf.com/
johnK
Member #: 690
Norfolk
look out for some awesome results (relative gains) on spi minis with single point injection - coming soon to a mag near you.
JK
If Carling made Mini engines
JK
Well I'd never have guessed :)
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=245176
It will be very interesting to see the difference between inner and outer cylinder AFRs.
JK
Hasn't that car been sold rescently?
I think they borrowed one:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=263627
johnK
Member #: 690
Norfolk
wrong guess folks - patience!
JK
