| Home > Help Needed / General Tech Chat > wastegate chatter | |||||||
117 Posts Member #: 144 Advanced Member |
29th Jun, 2004 at 11:58:10am
at the moment i have a totally std turbo lump in my mini, i am going to wind up the boost to about 10psi, i have no bleed valve fitted so i will be doing it on the actuator rod, if i do this, as i have no dump valve fitted, will the wastegate chatter, cos i dont like the sound of a poxy dv, i would much rather hear wastegate chatter. |
29th Jun, 2004 at 12:05:45pm
Shouldnt shorten the actuator rod, if you want 10psi get a 10psi actuator.
29th Jun, 2004 at 12:32:33pm
You will hear turbo chatter as there is no such thing as waste gate chatter!!!
AlexF |
29th Jun, 2004 at 09:19:18pm
thats the thing
![]() 151 Posts Member #: 165 Advanced Member Cambridge |
29th Jun, 2004 at 10:03:45pm
Trust me on this. Buy an actuator. And if you can't afford that buy a bleed valve. Do not preload the actuator to get more psi. |
29th Jun, 2004 at 11:20:59pm
buy one and then pre load it AlexF |
30th Jun, 2004 at 10:59:38am
whats the difference in me buying a new actuator when the stanard one is adjustable and will raise the boost for me? can someone explain why i should buy a new one? |
30th Jun, 2004 at 11:19:58am
The standard one isnt adjustable, just the length of the arm is to suit specific applications.
30th Jun, 2004 at 12:00:21pm
In short, but an actuator!
30th Jun, 2004 at 12:32:36pm
Yep |
244 Posts Member #: 34 Senior Member |
30th Jun, 2004 at 01:21:26pm
How do you set up the length of the rod with an unknown actuator?
30th Jun, 2004 at 01:21:39pm
oh!
30th Jun, 2004 at 01:31:48pm
Nope, just as dave says, you need a pre-load. I.e. how far you have to pull the rod to get it onto the wastegate with the wastegate fully closed.
126 Posts Member #: 244 Advanced Member |
30th Jun, 2004 at 02:31:12pm
re:
Speedster turbo under construction |
30th Jun, 2004 at 04:31:02pm
yep, 1.5mm is low, but having tried a few things, it seems that using a 'higher' pressure actuator, but only putting a small pre-load into it seems to makes the boost control even more stable...
30th Jun, 2004 at 05:24:50pm
Yeah well ive only played with the 4psi one so its easy to move |
30th Jun, 2004 at 06:02:07pm
im also using that MBC you saw iain :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
30th Jun, 2004 at 06:22:43pm
DVs protect turbos... not speed up gearchanges AlexF |
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
30th Jun, 2004 at 10:07:18pm
repeatability on single acting actuators can only be obtianed by springs (general). you may try by adding a pull spring in line with the rod
