Home > FAQ / Knowledge > fitting kad 6 pots
andywaller
Member #: 1826
Maldon Essex
it seams there isnt much info on fitting KAD 6 pots with vented discs anywhere so here is something i have done quickly.
sorry about the quality i need to get a CAD package on my PC!
you need.
KAD 6 pots
metro vented discs
mini drive flanges
the front of the steering arms which faces the dics needs grinding back to allow clearance
the inside of the discs needs to be machined like this
hope this helps and its all correct!
Edited by andywaller on 13th Nov, 2007.
porno six pots.... nice
mini23
Member #: 1296
Milford Haven Pembrokeshire
Why have you removed material from the inside of the disc?
andywaller
Member #: 1826
Maldon Essex
because with the KAD set up you run mini drive flanges. if you dont remove the material the front of the hub will rub on the inside of the disc.
mini23
Member #: 1296
I've got them fitted with no machining and no rubbing.
They are 8.4's I don't know if thats the same size as you have or wether it makes any difference.
Scruffy
Member #: 328
Seaford Rise, South Australia
No machining either for me!
On 5th Sep, 2011 Vegard said:
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Did they come with the kad kit?
I had to machine the outside of mine but not the inside, but I am using metro hubs.
You can get the discs done from KAD for about 90 quid, but if likke andy and me you have access to a lathe you can mod a set of 20quid discs :cool:
mini23
Member #: 1296
I bought the whole setup from KAD so I guess thats why they fit.
Good to know for future reference.
Jordan
Member #: 1392
Eventually anyway. *tongue*
lol,
that was the cheap ones for the fester conversion. i managed ok when i did the vents for the 6 pots.
Going the same route myself, got the £20 discs, just need to find a weekend when Fat Stig* is free so I can use his lathe to turn them down.
* = TM post whore who is a bit busy at the moment & not posting very much.
Fastcarl is machining mine at the moment , my 20 quid discs foul on the hub aswell. Il let you all no if i have any more problems or better still the solutions to them.
Rick
