Page: |
Home > A-Series EFI / Injection > Going turbocharged and injection | |||||||
152 Posts Member #: 1074 Advanced Member Northamptonshire |
31st Oct, 2007 at 10:49:16pm
Edited by matnrach on 1st Nov, 2007. |
1st Nov, 2007 at 09:31:27am
You will get charge robbing with the setup you describe. At low speed and light loads the short injection pulse will not get distributed to all four cylinders.
1st Nov, 2007 at 10:19:24am
Maybe I described my setup incorrectly.
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
1st Nov, 2007 at 11:42:19am
No offence, but that setup is not really any better than an SU, and costs far far more, is it really worth it?
1st Nov, 2007 at 12:45:36pm
I think it should be better for a few reasons:
1st Nov, 2007 at 01:13:01pm
Tom is right. The SU is very good and unless you get the injection just right, you will not better it.
1st Nov, 2007 at 02:34:08pm
1) Possibly, but with the SU proven to flow enough air for a 200bhp engine, is it an issue? NO.
Edited by Tom Fenton on 1st Nov, 2007.
1st Nov, 2007 at 03:56:46pm
Having said all that, I think that it will "work" and you will find it reasonably driveable with a bit of luck.
Edited by Paul S on 1st Nov, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1st Nov, 2007 at 04:32:42pm
Tom,
1st Nov, 2007 at 04:42:11pm
Glad to see you've taken the comments in the spirit in which they were intended, although the ECU may appear "cheap" having recently been through the process of fitting injection to a car that did not have it before, it is almost certainly everything else that soon starts to add up, suitable fuel pump (even more so if you are planning on 5 bar fuel pressure, why so high?), fuel filter, regulator, injectors, throttle pot, throttle body, sensors for the ECU, intercooler pipework etc etc etc.
1st Nov, 2007 at 05:01:25pm
Tom,
6745 Posts Member #: 828 Post Whore uranus |
1st Nov, 2007 at 05:06:16pm
im seriously thinking of this approach mat , i have a 1310cc running 150 bhp at around 9 psi ,and am happy with the fuel curve of the carb on full power throughout the range ,but to get it to run the air fuel rations i want at cruise and transient ,is proving dificult , iam pushing the lean run cruise envelope though ...
1st Nov, 2007 at 05:47:26pm
Robert,
1st Nov, 2007 at 06:18:39pm
Roberts sentiments echoed here as regards fuelling at cruise...
11046 Posts Member #: 965 Post Whore Preston On The Brook |
1st Nov, 2007 at 06:39:20pm
SPi rules On 26th Oct, 2004 TurboDave16v said:
1st Nov, 2007 at 07:31:03pm
Now we all seem to be agreed that single throttle bodied injection is at least a sensible way to go, has anybody got experience of the MS V2.2 or MSII
4559 Posts Member #: 786 Post Whore Bermingum |
1st Nov, 2007 at 07:56:52pm
1st Nov, 2007 at 08:08:48pm
Thanks for info
Page: |
