Page: |
Home > Help Needed / General Tech Chat > Is structual strength significantly compromised by a bulkhead box? | |||||||
4307 Posts Member #: 1321 Post Whore Wiltshire |
30th Oct, 2007 at 01:23:15pm
By cutting a large chunk of box section away to make way for the t3, is the shell stiffness reduced by a significant amount? Also in an accident, will the bulkhead will just fold?
Edited by minimole23 on 11th Jan, 2008. On 7th Oct, 2010 5haneJ said:
30th Oct, 2007 at 01:58:30pm
Of course it is. How much however is hard to say. Many use rollcages in their trackday warriors, these obviously rectify this + more. On 13th Jul, 2012 Ben H said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
30th Oct, 2007 at 02:23:23pm
i think in a crash the bulkhead is gonna be the last of the problems...but i think the box's are made with thicker metal anyway so there'd be no real big strength lost...maybe lol
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 2370 Posts Member #: 719 Post Whore Horndean - Near Portsmouth |
30th Oct, 2007 at 03:25:01pm
The cross member which the bulkhead box replaces part of is box section which is the strenghening for the bulkhead itself, when you fit the bulkhead box its concave on relation to this and youve obvioulsy removed the barcing box section that was there before so yeah it will definately be weaker!
Edited by richminiturbo. on 30th Oct, 2007. |
30th Oct, 2007 at 04:12:55pm
i would say the bulkhead must be weaker even with a seam welded box and the subframe bracing kit.
![]() 6748 Posts Member #: 828 Post Whore uranus |
30th Oct, 2007 at 05:43:57pm
in mine , i have welded captive nuts on the subframe in 4 places along the engine side at the top ,then packed the space between the frame and the body with plates of steel ,then put a plate inside the car and bolted the whole thing ,plate, body, packing ,and sub ,all together in the 4 places with m8 ht bolts ,this prob makes it all a bit more rigid ,you could try that if your worried ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Oct, 2007 at 05:59:30pm
I've done a similar thing to Robert, with a packer and 3 off M10 HT capheads.
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
30th Oct, 2007 at 07:42:12pm
i can say that they definatley do weaken the structure, i have cut out my upper bulkhead as im fitting a large air box, with the lower bulkhead in one piece it was fine, but once cut out and the turbo box re welded (seam welded) in there is definate flex there.
![]() 214 Posts Member #: 1574 Senior Member Malta |
30th Oct, 2007 at 09:08:34pm
Well this is how I did mine and I dont think it'll be any worse than it was before the mod. Certainly worth spending a bit of time to get right.
30th Oct, 2007 at 09:11:09pm
3591 Posts Member #: 655 Post Whore Northern Ireland |
31st Oct, 2007 at 01:46:21am
I would say that yes it does weaken it...
31st Oct, 2007 at 10:15:31am
I have done some reasoning, and decided that as most turbo minis have them welded in so I will stop worrying and get on and chop the bulkhead when the time comes.
31st Oct, 2007 at 03:15:29pm
PS- There is only one "a" in "bulkhead" :)
1425 Posts Member #: 690 Post Whore Norfolk |
31st Oct, 2007 at 09:00:04pm
Removing that much of the crossmember will reduce its rigidity by at least 50% or more - that is torsional rigidity, for compressive strength it would be reduced by a far greater percentage - probably 80% or so. No matter how thick a gauge of metal you weld back in you will never regain the rigidity in this method - if you want to regain the strength you need to add section - box, tube etc across the dash rail area at least with large spreader plates tied into the crossmember at its ends and in the middle, to reform a "section" for the forces to react against.
If Carling made Mini engines
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
3rd Nov, 2007 at 11:42:19am
Taking out the box section from the bulkhead lowers its strength end of. It dosen't matter how you weld in yor box. You have replaced a box section with a pan type structure. |
3rd Nov, 2007 at 01:23:01pm
5th Nov, 2007 at 01:28:30pm
Well thats cleared that up well.
5th Nov, 2007 at 05:54:10pm
my idea to being back regidity was to make almost a strutbrace from each of big bolts at the top of the subframe wich if im not mistaken are part of the suspention. i was going to have a brace going from each of the mounts back into the car and then accros the back then bolted to the bulkhead box. no idea if this would work but im going to give it a go Drives
Page: |
