Page: |
Home > A-Series EFI / Injection > Exhaust Gas Temperature | |||||||
29th Oct, 2007 at 10:30:39am
I'm hoping to test the Siamesed Port code by Christmas on my NA 1275.
29th Oct, 2007 at 10:52:46am
what about using a K type probe that is just 2wires joined at the tip, this could then be fitted between the manifold and gasket with a bit of exhaust paste. try looking at rswww.com |
29th Oct, 2007 at 01:28:33pm
I mentioned this some time ago - in Carl Austin's nat-asp racer with the open pipes - the centre pipe is a lot hotter than the outers.
29th Oct, 2007 at 01:39:05pm
On 29th of Oct, 2007 at 01:28pm TurboDave said:
Here is an idea - why not set up the 1275 with O2 AND thermocouples? That way you'll at least have a real indication if they do track (scuppering my thoughts- LOL) or if they do deviate, by what percentage - maybe plotted against RPM? Well, that's what I intend to do, but didn't phrase it very well. I'm sure the centre "ports" do run hotter, but the gas should not given the 360 degree pulse separation. If it does on the NA then we can factor it into the boost test/setup. I can tap the cast iron LCB style manifold on the NA 1275 and fit a compression fitting to hold the maplin thermocouple in the gas stream. The only problem that I have is that the Innovate Aux Box can only monitor one thermocouple directly. I need to convert the other(s) to a 0-5v signal :( Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Oct, 2007 at 01:50:55pm
If you don't want the manifold itself to skew the readings, then some form of 'insuator' between the manifold and the temp sensor needs to be found I reckon... The compression fittings for the K-types I'm familar with would easilly pass a lot of heat into the sensor. There MUST be a sensor out there, maybe in a K-type frame - but where the sensor tip (and measuring part) is isolated from the body? On 17th Nov, 2014 Tom Fenton said:
29th Oct, 2007 at 02:02:22pm
I think that if we get the tip of the thermocouple in the middle of the air stream we will be OK.
Edited by Paul S on 29th Oct, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11046 Posts Member #: 965 Post Whore Preston On The Brook |
29th Oct, 2007 at 06:48:41pm
If the center is running hotter it is running richer. advancing the ignition on the center cylinders will give more complete combustion resulting in a cooler gas.
Edited by Sprocket on 29th Oct, 2007. On 26th Oct, 2004 TurboDave16v said:
6745 Posts Member #: 828 Post Whore uranus |
29th Oct, 2007 at 07:28:28pm
generally lean means hot, rich means cooler .
29th Oct, 2007 at 07:58:25pm
I see where you are coming from Robert.
3588 Posts Member #: 655 Post Whore Northern Ireland |
29th Oct, 2007 at 07:58:32pm
Isnt it only the tip of the thermocouple that actually reads temp anyway ??
29th Oct, 2007 at 08:08:30pm
On 29th of Oct, 2007 at 07:58pm stevieturbo said:
Isnt it only the tip of the thermocouple that actually reads temp anyway ?? I had a play with the TC-4 on my volvo td, and I thought response from the 3mm sensors I was using was fairly good. Not, it isnt instant, but it isnt that slow either. Just this minute decided that I'll have to get the TC-4! After searching the net trying to find an amplifier, I find Innovate do one. It's a bit steep at £100 but no easy option. At least it will daisy chain with the LM-1 and LMA-3. I'm hoping that the combination of widebands and EGTs will answer some of these theories. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Oct, 2007 at 10:32:11pm
On 29th of Oct, 2007 at 07:58pm Mini Sprocket said:
I see where you are coming from Robert. I was under the impression that the highest combustion temp is actualy on the rich side of Stoichometric, may have been fed duff info one thing i have noticed is, obviously, the EGT rises as you go to full throttle, the AFR is richer yet the temp rises. The cylinders are working harder, more charge is being drawn in, cylinder pressures are higher and combustion temps rise. All i was saying is that on a siamese port onec cylinder starts drawing as the other has finished, valves are still open. is it not reasonable to suggest that the cylinders starting to draw on the port will draw some of the charge out of the other cylinder, thus reducing its VE? you would then get a temperature difference between pairs of cylinders as two are working harder than the others. It has nothing to do with AFR, just cylinder filling. Its physics rather than chemistry. Scatter cams were developed to reduce this effect, and im surpised no one is even contemplating using the Kent MD274SP for this reason!! thats a good graph sprockster , i think i may be talking about the .8 to .9 range ,before its into the 14.7 to 1 lambda 1 area ,when things get so lean its getting cooler ,, with due rspect to what your saying on the port robbing issue , i can see that argument ,but also then think ,hey , if the second port is robbing from the 1st ,then it has to change the direction of the inertia gas flow that is flowing into the 1st open port ,before it starts to get its share ,so the thing can be seen in two ways , obviously the way around that scenario is to make the port as small as poss to create as much velocity as poss .,while of course ,still getting the high rpm flow needed for a long power curve . another thing is that ,even if the gas changes flow from say ,cyl 2 to 1 ,then the fuel suspended in that air stream will not be so willing to change direction ,so ,the cylinder doing the robbing would get a leaner slug for a moment.. Edited by robert on 29th Oct, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Oct, 2007 at 12:15:10am
Best lambda for torque is around 0.86, thats roughly 12.5 AFR, going richer doesnt always produce more power, what it does do is cool the combustion temps down, hence why many tuners use this method to reduce the possability of detonation, but going less then a Lambda of 0.7 you are starting to get into the visable black smoke and rich missfire area. Your wideband wont read at these levels either, it certainly wont be an acurate reading.
Site Admin 8506 Posts Member #: 16 Sold the turbo and seeing what the C20XE can do! Near Lincoln |
30th Oct, 2007 at 01:37:35am
our lean burn is 30:1 gas turbine though!
30th Oct, 2007 at 03:15:30pm
The Maplin thermocouple is no good as it does not do the temperature range.
30th Oct, 2007 at 05:23:05pm
have a look at picoscope paul. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Oct, 2007 at 01:50:17am
What does Picoscope do ? ( have a similar, but cheaper PC scope )
Edited by stevieturbo on 31st Oct, 2007. 9.85 @ 145mph
31st Oct, 2007 at 05:12:04am
they do various data logging stuff steve , iv got the 8 channel i think at home so i will have a play with it when i get back in dec . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Oct, 2007 at 08:56:23am
To use the TC-4 for logging, you have to connect it up using the serial port to a laptop running Logworks.
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
31st Oct, 2007 at 01:30:01pm
I have access to FeKo sensors if they are any use to you? I know we use them up to 300 C and im sure they are capable of withstanding higher temps.
31st Oct, 2007 at 02:14:51pm
We need something that will work up to 1000 degrees C !
5th Nov, 2007 at 03:39:57pm
I've bought two thermocouples from TC-Direct.
31st Dec, 2007 at 01:07:02pm
The Innovate TC-4 that I'm going to use to log the Exhaust Gas Teperatures has four inputs. As I'm only using two, I have two spare.
31st Dec, 2007 at 02:50:08pm
On the topic of EGT's and logging...
24th Mar, 2008 at 05:34:27pm
Fitted the thermocouples this weekend. Not a lot but too cold and feeling iffy. Plus sturgeo decided to fit Hi-Los today and I ended up helping him, as usual.
Page: |
