Home > FAQ / Knowledge > CAM Specifications 'A Series' Engine
MG 'A Series' Engine CAM Specifications
.....a project in process. data is in complete
and constantly being updated.......
Special Note!(The manufactures listed here were found on the web, or listingsfrom other various documents at hand. They are listed herefor reference only and are not guaranteed to be exact. Checkwith the manufacturer for final specs.)TT= Triumph Tune (Moss International) http://www.mossint.co.uk/K = Kent Cams http://www.kentcams.com/E = Elgin Cams http://www.elgincams.com/c-aus2.htmlP = Piper Cams
This is a table of the stock cams used that I have been able to find.
Leyland Factory cam shaft specs
Cam Grind No Valve Overlap Cam Lift Valve Lift Inlet Open Inlet Close Exhaust Open Exhaust Close Inlet Period Exhaust Period Valve Clearance
8G712 15 0.221 0.285 4 45 41 10 230 230 0.012
2A297 15 0.221 0.285 4 45 41 10 230 230 0.012
2A571 15 0.221 0.285 4 45 41 10 230 230 0.012
AEG148 26 0.250 0.318 5 45 51 21 230 252 0.012
AEG537 26 0.250 0.318 5 45 51 21 230 252 0.012
AEG510 31 0.250 0.318 10 50 51 21 240 252 0.015
AEG542 31 0.250 0.318 10 50 51 21 240 252 0.015
88G229 37 0.250 0.318 16 56 51 21 252 252 0.015
C-AEG567 37 0.250 0.318 16 56 51 21 252 252 0.015
C-AEA731 53 0.252 0.320 24 64 59 29 268 268 0.015
? 53 0.252 0.320 24 64 59 29 268 268 0.015
Q2629 70 ? ? 20 80 50 50 280 280 0.015
C-AEA544 73 0.306 0.388 34 74 69 39 288 288 0.015
C-AEA648 95 0.315 0.394 50 70 75 45 300 300 0.015
C-AEG529 95 0.315 0.394 50 70 75 45 300 300 0.015
C-AEG597 105 0.315 0.394 60 80 75 45 320 300 0.015
C-AEG595 115 0.315 0.394 60 80 85 55 320 320 0.015
This is a few of the 'modified' profiles for cams usable in an
MG Midget that I've been able to find.
Modified cam shaft specs
profile nameand source Intaketiming Exhausttiming seatduration .050"duration camshaftlift power range(mfr' claim) Max BHP@ speed lash application
E 66-15 264 217 .262 I .015E .017 ONE STEP UP FROM STOCK.
E 67-18 268 222 .289 I .018E .020 1275-NEEDS PERFORMANCE SPRINGS
E 685-16 274 230 .295 I .016E .018 SPRINGS + PORTED HEAD RECOMMENDED.
E 70-9 280 228 .263 I .009E .011 HOT STREET 9:1, SPRINGS + HEADER.
E 70-10 280 228 .278 I .010E .012 HOT STREET 9:1. SPRINGS, HEADER, REWORKED HEAD.
E 71-15 284 235 .290 I .015E .017 AUTOCROSS 9.5:1 SPRINGS, GOOD HEAD, + WEBER.
E 715-18 286 242 .302 I .017 E .019 AUTOCROSS 10:1SAME AS ABOVE.
E 72-10 288 235 .290 I .011 E .013 AUTOCROSS 10.5:1SAME AS ABOVE.
E 75-15 300 250 .297 I .014 E .016 RACE GRIND. 11+:1SAME AS ABOVE.
E 75-12 300 250 .323 I .013E .015 RACE GRIND. REQUIRES BETTER HEAD THAN ABOVE.
E M77-13 308 255 .321 I .014 E .016 FULL RACE APPLICATION 45-7500 RPM. 12+:1
E 765-14 306 261 .341 I .014E .016 RACE. 12.5:1 REQUIRED
E 77-12 308 263 .348 I .014E .016 RACE 13:1 MAX FOR PREPARED 948cc, MUST DYNO TUNE.
E 775-18 310 268 .380 I .022E .024 RACE. WORKS BEST FOR 1275-1440cc ENGINES.
KENT CAMS (MEGADYNE RANGE)
DurationIn / Ex LobeCenter Lift at1.25 ratio lift at1.5 ratio
MD256 Mild Road 254/254 106 .320/.320 .380/.380
MD266 Fast Road 260/268 106 .320/.330 .380/.390
MD276 Road Rally 270/280 106 .360/.380 .430/.455
MD286 Rally 280/290 106 .388/.400 .460/.468
MD296 Race 290/300 106 .400/.420 .470/.495
MD310 Full Race 310/310 106 .420/.420 .495/.495
KENT STANDARD CAMS
Duration Lift at lift at
In / Ex 1.25 ratio 1.5 ratio
450/500 Mild Road 252/262 .320/.320 .380/.380
*948/567 Mild Road 252/252 .320/.320 .380/.380
550/600 Fast Road 288/288 .360/.360 .430/.430
*731/800 Fast Road 268/268 .320/.320 .380/.380
*544/643 Road Rally 288/288 .387/.387 .464/.464
*649/530 Race 300/300 .394/.394 .472/.472
*Sprint 597 Race 320/320 .394/.394 .472/.472
*Super Sprint 598 Race 320/320 .394/.394 .472/.472
895 Race/Rally 300/320 .395/.395 .475/.475
475 Full Race 320/315 .396/.395 .475/.475
* Denotes BL's ST Spec cams
KENT MEGADYNE SCATTER PATTERN CAMS
Timing Timing No. Lift at
No 1 & 4 No 2 & 3 1.25 ratio 1.5 ratio
MD286S 34-66 71-39 34-66 71-39 .388/.400 .460/.488
MD296S 39-71 76-44 39-71 76-44 .400/.420 .470/.495
MD290S 41-69 73-37 47-63 67-43 .395/.395 .472/.472
MD310S 49-81 81-49 49-81 81-49 .420/.420 .495/.495
Elgin Cam info
Camshaft No. Seat to Seat Duration In / Ex Duration @ .50 cam lift Cam lift In / Ex Valve Lift In / Ex 1.25 rockers Valve Lift In / Ex 1.5 rockers application
CAM001 244/264 198/215 .264/.264 327/327 393/393 Mild Road. Smooth Idle.
CAM002 250/264 208/215 .250/.264 312/327 375/393 One up from Cooper 'S' Spec.
CAM6608 264/264 217/217 .262/.262 327/327 393/393 Max. for smog emmissions
CAM003 264/268 215/222 .264/.289 327/358 393/430 Fast Road Cam.
CAM004 262/268 225/230 .293/.318 366/397 439/477 Fast Road Cam. 9.1:1 compression recommended.
CAM6708 268/268 222/222 .289/.289 361/361 433/433 Mini & 1275. Will work with stock engine.
CAM6707 268/268 230/230 .318/.318 397/397 477/477 Heavy duty springs reqd. Cylinder head porting recommended.
CAM005 268/278 230/240 .318/.321 397/401 477/481 Hot Street. Header recommended. 9.5:1 compression.
CAM7008 280/280 228/228 .263/.263 329/329 395/395 Hot Street. Must have header to idle. 9.5:1compression, heavy duty valve springs & good cyl.head are required. Adv. cam +2 deg.
CAM7007 280/280 228/228 .278/.278 348/348 417/417 Hot street grind. Same reqs as above.
CAM7107 284/284 235/235 .290/.290 363/393 435/435 Autocross. 9.5:1 compression required.
CAM71506 286/286 242/242 .302/.302 378/378 453/453 Autocross. 10:1 compression required.
CAM7207 288/288 235/235 .290/.290 363/363 435/435 Autocross. 10:1 compression required.
CAM006 288/292 235.254 .293/.321 366/401 439/481 Autocross. 11:1 compression. Pump gas okay.
CAM7505 300/300 250/250 .297/.297 371/371 446/446 Race grind. 11:1 compression reqd.
CAM007 300/300 250/250 .323/.323 404/404 485/485 Race grind. 11:1 compression reqd.
CAM76506 306/306 261/261 .341/.341 426/426 512/512 Full race. 13:1 compression reqd.
CAM7706-32 308/308 255/255 .322/.322 403/403 483/483 Full race.13:1 compres.Power ramge from 4500-7500
CAM7706-34 308/308 263/263 .348/.348 435/435 522/522 Full race. 13:1 compression reqd. Max. for a fully prepared 948cc. Dyno tune
CAM73503 310/310 268/268 .380/.380 475/475 570/570 Race. Works best for 1275 - 1480cc engines.
P = Piper Cams
Edited by BENROSS on 17th Aug, 2007.
its a shame we cant display a spreadsheet on the forums, the spacing all goes to cock when you click on 'post'
Hedgemonkey
Member #: 360
I think the 649 one is wrong off the top of my head.
Jackman
Member #: 984
Westhoughton, Bolton
OOO was going to post a cam post, my friend has a cam in a 1400 which he was given with the code KC300, ive never heard of that, has anyone else?
Manchester Minis
kent cams?? 300deg?
Jackman
Member #: 984
Thats what i though at first but i thought id ask people with more knowlege. Thanks.
Manchester Minis
8PortChris
Member #: 246
Cumbria
KC---Keith Calver ?
stefaz
Member #: 1656
stoke-on-trent
Kent Cams I believe mate
racing_is_life
Member #: 1426
Birstall, Yorkshire
You need to add 274 scatter pattern to Kents range, thats what i got in my daily drive. If you need spec i'll dig it out.
Rich
