Page: |
Home > MS Code Discussions > MPi injection characteristic data | |||||||
13th Aug, 2007 at 12:14:52am
Well, this superceeds everything we have thought / believed we knew in the past about the MEMS MPi.
Edited by TurboDave16V on 11th Oct, 2007. On 17th Nov, 2014 Tom Fenton said:
13th Aug, 2007 at 02:07:18am
Thank you for doing that work. This is very interesting and intriguing data.
13th Aug, 2007 at 04:58:32am
This did come across as negative
13th Aug, 2007 at 06:50:40am
Sorry about that, that was not my intent. I'll elaborate a bit on the why I say I would need more information.
6745 Posts Member #: 828 Post Whore uranus |
13th Aug, 2007 at 09:49:04am
fascinating,thank you dave .thats very usefull.
13th Aug, 2007 at 09:59:05am
Dave, thanks for the data ..... certainly has me thinking!!! I am with Jean however that TDC / cam triggers would have been useful (reading the other post I see you tried to get a TDC signal but it didn't work out for you).
13th Aug, 2007 at 10:33:39am
Very interesting.
13th Aug, 2007 at 12:04:11pm
Some more thoughts on the data:
Edited by Paul S on 13th Aug, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th Aug, 2007 at 02:34:11pm
Awight Guys!
13th Aug, 2007 at 05:17:33pm
I had earlier assumed that the TDC at or before the injection point was the TDC when the intake valves were open.
13th Aug, 2007 at 07:24:48pm
I showed this to my mate Graeme earlier - and a lengthy discussion started, where we suspect we migth have an answer.
13th Aug, 2007 at 07:26:31pm
Does anyone have a wiring diagram for the K-series and A-series including pin-outs on the ECU for 1997 model year MEMS?
4559 Posts Member #: 786 Post Whore Bermingum |
13th Aug, 2007 at 07:34:48pm
Edited by Bat on 13th Aug, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
11046 Posts Member #: 965 Post Whore Preston On The Brook |
13th Aug, 2007 at 08:11:11pm
Dave, they are wired in the loom
Edited by Sprocket on 13th Aug, 2007. On 26th Oct, 2004 TurboDave16v said:
1497 Posts Member #: 100 Parisien Turbo Expert Paris\' suburb |
13th Aug, 2007 at 08:15:13pm
On 13th of Aug, 2007 at 07:24pm TurboDave said:
- OR - they're wired together inside the MPi loom. I can open an mpi wiring loom to see. what could perhaps help you to "handle" how they done it, is that I know that a 114 gti spi mems does work on a cooper spi. |
13th Aug, 2007 at 08:16:44pm
On 13th of Aug, 2007 at 08:15pm fab said:
if you're looking for: On 13th of Aug, 2007 at 07:24pm TurboDave said:
- OR - they're wired together inside the MPi loom. I can open an mpi wiring loom to see. what could perhaps help you to "handle" how they done it, is that I know that a 114 gti spi mems does work on a cooper spi. I Know, but it does help if you have 1400ccs as well On 26th Oct, 2004 TurboDave16v said:
7 Posts Member #: 1874 Junior Member Swindon |
13th Aug, 2007 at 09:33:29pm
Firstly, good work TurboDave!
2909 Posts Member #: 83 Post Whore Glasgow, Scotland |
13th Aug, 2007 at 09:39:51pm
with regards the adaption of the ecu, i jsut had a quick look over the diagrams, the MPi mini does indeed have 4 injector outputs, paired together in the wiring loom and one pair drivign each injector. Wiring diagram for the VVC mems unit show the same injector pin numbers but one for each injecor. jsut to confirm what you already thought! turbo 16v k-series 11.9@118.9 :)
13th Aug, 2007 at 10:08:54pm
this is the difference though, the MEMSJ2 ECU and KV6 engine was designed to run two seperate cylinder banks and as such two seperate fuel tables. The wiring for this ECU also shows two lambda sensors to suport this. In escence its two seperate 3 cylinder engines.
13th Aug, 2007 at 10:26:09pm
MPi flywheel data
13th Aug, 2007 at 11:08:05pm
On 13th of Aug, 2007 at 09:59am RogerM said:
(Rob H .... I know your reading this .... I need your help ..... well at least your wideband ..lol) Read yes, but struggling to follow, anyway I'm more than hapy to lend my wideband to the cause. EDT: After you weld my cage in. Edited by Rob H on 14th Aug, 2007. Isambard Kingdom Brunel said:
14th Aug, 2007 at 10:21:47pm
Rob .... thanks for that, it's a great start.
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
14th Aug, 2007 at 10:55:27pm
Mine is available for testing if required.
6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
15th Aug, 2007 at 08:39:37pm
why has everyone on this topic started talking fooking Russian,
15th Aug, 2007 at 08:59:33pm
Which is why I wired the ECU in The DON and you didn't........LOL!!!!!
Page: |
