Page: |
Home > 998cc > 998turbo, i have a breathing problem! | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
5th Aug, 2007 at 11:18:44pm
right the prob i have is due to the turbo on the bk of the 998 i have to have a non-breather tappet chest cover so how to i get the engine breathing as much as it should?
5th Aug, 2007 at 11:38:17pm
5th Aug, 2007 at 11:56:11pm
i'll have to drill & tap my housing then, & i'll use the breather from my tappet cover & weld that to a pipe & make a base to go on the housing! should do the job!
6th Aug, 2007 at 12:00:08am
6th Aug, 2007 at 12:04:32am
is the wire woll needed, i mulled over the idea of taking it out of my breather or am i wrong to do so!
6th Aug, 2007 at 08:05:30am
You only need the wire woll if you are feeding back into the carb, not needed for a catchtank.
6th Aug, 2007 at 01:03:34pm
i was reading this in the search last night will about it not being needed if using a catchtank, saves some greaf, i'm gonna get the hacksaw & welder out & get some of my fabrications skills on the go "brace yourselves for real dodgy welding" lol SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
6th Aug, 2007 at 01:28:28pm
Either make the catchtank easy to remove so you can tip any oil out, or put a drain plug in.
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
23rd Nov, 2008 at 10:44:40pm
would it be possilbe to fit a drain to the catch can and drain it back in to the engine via the breather on the crank case(mg and turbo engines have)
23rd Nov, 2008 at 10:53:14pm
this is what a friend of mine does on his 106 rally car to prevent him running out of oil after 5 mins, his engine breathes extremely heavily when booted "Turbo's make torque, and torque makes fun"
![]() 8604 Posts Member #: 573 Formerly Axel Podland |
23rd Nov, 2008 at 11:25:42pm
This is how I've done mine.
Edited by Paul S on 23rd Nov, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
Page: |
