Page: |
Home > General Chat > Does anyone here lengthen the clutch pin (the one for the slave) | |||||||
![]() 3341 Posts Member #: 218 Post Whore Bingley, West Yorkshire |
1st Jun, 2007 at 07:02:45pm
Does anyone here lengthen the pin/plunger/bar whatever its called, that goes into the clutch slave? Had trouble on my last engine with it not disengaging properly, and having problems now, even with my carpets out and foot to the floor it only just goes into gear.
1st Jun, 2007 at 07:05:35pm
Wolfie made some. All I've done is weld a piece into the rod.
76 Posts Member #: 1038 Advanced Member |
1st Jun, 2007 at 07:06:58pm
I lengthened mine but found that I was snapping clutch arms at a rate of about 1 every 3 months.
1st Jun, 2007 at 07:08:34pm
im using a short arm, what kind did you snap danwebster? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
1st Jun, 2007 at 08:30:50pm
I have a selection of different length pins, just weld a bit on to them to make them longer, although I normally try to use the shortest pin that works as you want make sure the clutch fully releases. Isambard Kingdom Brunel said:
1st Jun, 2007 at 08:32:49pm
found the link, thanks dave
1st Jun, 2007 at 08:43:38pm
1/8 of an inch should sort it, although I've used longer on the MG before, tbh if it needs much more than an 1/8 then the clutch probably needs some tlc. Isambard Kingdom Brunel said:
1st Jun, 2007 at 09:35:25pm
cool its a new clutch so 1/8 or less should do, thanks rob :) Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
1st Jun, 2007 at 10:49:19pm
an excellent write up by turbo dave as usuall
34 Posts Member #: 1634 Member |
4th Jun, 2007 at 11:18:07pm
i had mine threaded and another to screw over the top - i have full adjustment, i needed it because running verto clutch with pre verto slave ect... it didnt quite push enough to engage properly |
Page: |
