Page: |
Home > MS Trials & Testing > cables for MS / megastim? | |||||||
10th Apr, 2007 at 05:21:12pm
I've built up my stimulator, and am about to start on my ECU using the megabuild manual.
Edited by TurboDave16V on 10th Apr, 2007. On 17th Nov, 2014 Tom Fenton said:
10th Apr, 2007 at 06:33:18pm
connecting a stim to a regular megasquirt? they jus tplug directly into each other, one has a male and the other a female DB37 :) turbo 16v k-series 11.9@118.9 :)
10th Apr, 2007 at 06:34:51pm
or are you useign one of these fancy missign tooth stimulators? if so you can hook a regular stim to the megasquirt, and cut the regular stims rpm trigger out and substitute your own, worked for me whilst playing wit hthe rover 36-1-1-1-1 wheels this gives you a pretty fuss-free setup turbo 16v k-series 11.9@118.9 :)
10th Apr, 2007 at 07:15:25pm
oh - I think I've messed up then...
10th Apr, 2007 at 07:22:58pm
10th Apr, 2007 at 07:38:45pm
10th Apr, 2007 at 07:46:57pm
for what you want dave quickest and easiest setup is hook up the stim as normall. then note what trace on teh stim provides the "IRQ" signal to the megasquirt, cut this trace and then wire your crank position sensor in here. build the megasquirt up as you would for the VR input and your good to go. a few otehr small mod's to the stim and you can have flying leads comeing off to hook up to your scope for the injector and coil outputs and your ready to bench.
10th Apr, 2007 at 08:14:29pm
IRQ?
10th Apr, 2007 at 08:39:06pm
the stim board creates a single pulse liek a points system would create. to test toothed wheels i cut this out and substituted a signal from a crank position sensor pointing at the wheel i wish to run. when running an external wheel and sensor like this the circuit on the stimulator is defunct.
10th Apr, 2007 at 09:14:33pm
cheers Evo...
10th Apr, 2007 at 10:47:13pm
sorry about the typing by the way, i really should proof read before i hit post. turbo 16v k-series 11.9@118.9 :)
10th Apr, 2007 at 10:49:43pm
Evo,
10th Apr, 2007 at 11:03:41pm
I should have added that the breakout board can also be used for in-car diagnostics because you can plug it between the MS and the wiring harness and have access to all signals coming into and out of the ECU
10th Apr, 2007 at 11:05:23pm
wasnt bashing the breakout board atall jean, its specifically designed for the kind of thing that is going on here, and i agree, when i was benching my waisted spark setup and VR filtering circuits the stim got very messy with extra wires :) turbo 16v k-series 11.9@118.9 :)
10th Apr, 2007 at 11:20:05pm
I wasn't seeing your comments as bashing, don't worry. I just wanted to explain for everyone reading the thread. I've also modified my stim before I made the board :). It's just a lot easier and quicker to do with the breakout board and there's a lot more flexibility for both bench and in-car testing/diagnosing.
Page: |
